Terminal Server Break Sequence
Jul 20th, 2009
We have a lab where we ssh to a router and then telnet to a Terminal server from there in order to access a different lab. However, when executing the break sequence while connected to the Terminal server in order to exit out of one of the devices, it switches back to the rouer we initially ssh'ed to. Does anyone know if there's a way to override this? When we send the break sequence, we only want to break from the reverse telnet session back to the Terminal Server.
falcon.nathan Mon, 07/20/2009 - 17:31
Figured it out...not sure how to delete my posting, so i'll post what I found. CTRL Shift 6 TWICE, then X will send the break sequence to the second level connection. New one for me...
