dlsw circuit vs dlsw peer
Jul 20th, 2009
what is the different between dlsw circuit and dlsw peer? I had a problem where my dlsw peer is connected but my dlsw circuit is disconnect? what could possible cause this?
Giuseppe Larosa Tue, 07/21/2009 - 00:14
  • Hall of Fame,
    Founding Member
Hello Guo,
sh dlws peers shows the TCP sessions between routers.
It is a preliminary and necessary condition
sh dlsw circuit is the command that shows real SNA connections.
if no dlsw circ is listed there is no real DLSW connection
Check the lan interfaces on both sides either ethernet, token ring or other type (SDLC)
Hope to help
Giuseppe
