why con't setup tunnel between PEs?
Jul 20th, 2009
hi,i have a problem about multicast for mpls vpn.
ce1-Pe1-P-Pe2-Ce2.
at the core use ssm .but i don't know how to config P.the configuration of Pe:
ip multicast-routing
ip vrf a
rd 100:1
route-target both 100:1
mdt default 232.0.0.1
ip multicast-routing vrf a
ip pim ssm default
the configuration of P:
ip pim ssm default.
but display of the PE:
sho ip pim vrf a nei
only have the interface connect with CE .
why don't setup PEs ?
jon.harald.bovr... Mon, 07/20/2009 - 21:50
P-config:
ip pim ssm default
Interface config:
ip pim sparse-mode (on all relevant P and PE interface)
You might also need to enable 'address-family ipv4 mdt' on P/PE, dependent of HW/SW
A verification: show ip pim neigh on PE should show P-router as neigbour
