07-20-2009 10:57 PM
I want to check the hits for Port no. 20 on our cisco router, please suggest if there is any command on cisco router(Without affecting any working scenreio).
07-21-2009 06:38 AM
Kindly reply pls.
Have to check the no. of hits for & from port no. 20 on cisco Router/Switches.
07-22-2009 08:32 AM
Dear Freidzs,
No reply from any-one.
Is this so difficult..? Or the question is wrong or there is no solution for the desired result.
07-24-2009 04:45 AM
Hi Sam,
Is there any NAT configured with this port?
Where and how you opened this port on your router
Naidu.
07-26-2009 11:01 PM
HI Naidu,
No there is no NATing configured on router.
We just want to check the port no. 20 hits "To" and "From" the access connectivity IPs on the router.
07-27-2009 09:23 PM
Create an access-list with permitting first port 20 from any to any and then a line allowing all remaining traffic. Apply this ACL on the interfaces.
Then a show access-list will show you hits :
Extended IP access list 101
10 permit tcp any any eq tcp 20 (10 matches)
20 permit ip any any (6 matches)
This should not be production impacting.
