Changing Default SNMP port in router
Jul 20th, 2009
Hi All,
Is it possible to make the router listen to ports other than 161 for SNMP ?? can ip port-map help in this... MY NMS SNMP port to be changed to non 161 due to security issue
Joe Clarke Tue, 07/21/2009 - 07:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is not possible. You can send traps to non-default ports, but the SNMP agent will always bind to udp/161.
