How do manually Change a Cost in STP?
Jul 21st, 2009
I have to paths to our data center. I would like to increase the path cost of the secondary link so that the primary link will be used for Vlan 1.
Istvan_Rabai Tue, 07/21/2009 - 00:30
Config example for the secondary link:
conf t
interface gig1/0
spanning-tree vlan 1 cost 20
network_team Wed, 07/22/2009 - 01:08
attached is a current Cost flow for vlan 1 which works correctly all vlan1 traffic goes via the primary link and the blocking is done via the secondary link.
The proposed diagram we remove CS_2 from the network and connect the two cables into a layer 2 switch to directly connect the two networks when we do this the blocking moves from Dis_2 and we have intermittent connection on vlan 1. Could the problem be that Dis_2 doesnt block and this has caused the problem?
