Able to monitor hook/fault status of analogue device via fxs?
Jul 21st, 2009
Greetings all.
I've been asked to find out if it is possible to monitor the status of an analogue phone attached to a VG224 via a 24 port FXS interface.
Specifically I need to to able to tell if the phone is off hook or faulty, the problem being I have a VG224 which has 7 of the 24 ports configured and all 7 ring quite happily when dialled from an IP handset whether there is an analogue phone physically present or not.
I've found this MIB,
Will this be any use to me, we're running Solarwinds Orion Network management with the VOIP monitor plugin, among others.
Thanks in advance for any advice.
