Multiple Routing Tables - Sup 720
Answered Question
Jul 21st, 2009
Guys,
is this possible to do? If I want to have groups of vlans to have their own routing tables preventing the groups to route between eachother and push them to a default gateway of a firewall.
if so do you need any special hardware or software? Is an FWSM required?
Any good docs on this would be usefuly cant seem to find anything on it.
thanks
Correct Answer by Giuseppe Larosa about 8 years 2 days ago
Hello Mick,
this is possible with sup720
you can use VRF lite or full featured MPLS VPN to have separate routing tables and subsets of interfaces
see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/pfc3mpls.html#wp1047631
or
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/pfc3mpls.html#wp1047631
the difference is that in VRF lite no MPLS links are used and you need to provide dedicated logical links for each topology.
With MPLS this is not needed.
A FWSM is not required but it can completes the solution in some scenarios
Edit:
a design guide
http://www.cisco.com/en/US/docs/solutions/Enterprise/Network_Virtualization/PathIsol.html
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 07/21/2009 - 02:05
  • Hall of Fame,
    Founding Member
Hello Mick,
see
or
Edit:
a design guide
Hope to help
Giuseppe
