Problems with Re-Direct on WLC
Jul 21st, 2009
Hi Experts,
I want to implement a guest login for the WLAN, but the redirect of Guest login webpage is failing. Could some one assist what needs to be configured.
Thanks in advance,.
Neha
Roman Rodichev Sat, 07/25/2009 - 19:00
  • Gold, 750 points or more
are you doing "url-redirect" from ACS by any chance? I've noticed before that it will not work if WLC is configured as "RADIUS (Cisco Airespace)" in ACS. Once I changed to "RADIUS (Cisco Aironet)", it started to work. Not a good fix, since "RADIUS (Cisco Airespace)" is required to support Airespace AAA parameters. :(
Roman
manriquej Tue, 07/28/2009 - 09:33
Please make sure that you're web browser doesn't isn't set up to use a proxy server.
Also I remember one scenario where I got the web authentication (splash screen) working with Mozill firefox but I couldn't get it to work with Internet Explorer. I called Cisco TAC and they had me type in a command. The Web Auth splash screen did come up after this command was configured on the WLC. Unfortunately I can't remember the command. You can try giving Cisco TAC a call and see what you can find our.
Hope this helps,
Jorge
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
