kishan1984 Tue, 07/21/2009 - 03:10
sh module,if u have redundant sup it will show standby infromt of it.
dan_track Tue, 07/21/2009 - 05:09
I have a 6500 and it shows nothing when I run a "show module"?
Any thoughts?
The os is CATOS:
IOS (tm) MSFC2 Software (C6MSFC2-PSV-M), Version 12.1(22)E1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Dan
Giuseppe Larosa Tue, 07/21/2009 - 05:18
  • Hall of Fame,
    Founding Member
Hello Dan,
in hybrid mode
sh module has to be done from L2 supervisor
do sh cdp n det
from msfc (you are on the routing module that is a separate entity in hybrid mode)
your only CDP neighbor is the sup
and then connect to the supervisor
hope to help
Giuseppe
dan_track Tue, 07/21/2009 - 05:45
Hi Guiseppe,
Thanks very much for that. I'm realtively new to the 6500 switches. Can you please point me to somewhere that explains why the routing module is separate from the switch.
Also when I telnet to the switch does that mean I am connecting to the supervisor card?
Additionally I assume you can change supervisor cards easily. If I do change my card where is my config stored, will I lose that? Also how do I know if the backup supervisor card has had the running-config written to it, that is if the cofig is actually stored on supervisor cards?
Thanks for your help.
Dan
Giuseppe Larosa Tue, 07/21/2009 - 08:49
  • Hall of Fame,
    Founding Member
Hello Dan,
historically when Cisco bought Catalyst company C6500 and C5500 were L2 only switches and later routing modules have been added.
First approach was Hybrid mode with routing module using an internal high capacity trunk named 15/1.
When you telnet to L2 supervisor you connect to supervisor card.
the config is saved in NVRAM on the module.
In hybrid mode there is a L2 configuration under CatOS and a L3 configuration in the MSFC.
Commands to check redundancy
sh mls
sh module
sh redundancy
on l2 supervisors
sh module will show one sup as in standby mode.
Hope to help
Giuseppe
