WCS/WLC Disabled WLAN still broadcasts! BUG?
Jul 21st, 2009
Versions 6.0.182.0 on controllers (4 WISMs) and 6.0.132.0 on WCS.
Created a test WLAN which was used for a week or so, WPA2/PSK, broadcast ssid, standard stuff. I no longer wish to use it and set the enabled state in the template to disable and then saved and applied the template to the controllers. On various devices, I can still see it broadcasting! I have even checked on the individual controllers and the WLAN is set disabled, so no WCS sync issue. I also tried switching the broadcast ssid to off and reapplying it and this makes no difference.
If I try to connect to the WLAN, this fails, which is obviously a good thing! I have not tried to delete it yet as there are situations where we need the ability to enable/disable wlans.
Anybody else seen this issue before I report it to TAC?
ssoberlik Tue, 07/28/2009 - 08:18
  • Bronze, 100 points or more
If the WCS and WLC has been synchronized, you should not see this issue. Since you have already verified and ruled out a sync issue, this looks like a bug.
Trending Topics - Security & Network
