About CiscoWorks (LMS2.5)
Jul 21st, 2009
Hi all.
I'm not sure my question is right addressed in "Network Infrastructure" channel, so please eventually redirect me to the right channel.
Question:
we want to know if the CiscoView 6.1.2 component of the CiscoWorks
(LMS2.5) software support the sysObjectID .1.3.6.1.4.1.9.1.672 devices.
Thank you.
Gabriel
Giuseppe Larosa Tue, 07/21/2009 - 23:33
  • Hall of Fame,
    Founding Member
Hello Gabriel,
the right place for this question is the Network Management forum.
Generally speaking missing MIBs can be loaded respecting the correct order
using SNMP Mib navigator I can see the variable is in MIB
Object ciscoASA5540
OID 1.3.6.1.4.1.9.1.672
MIB CISCO-PRODUCTS-MIB ;
the tool provides you also dependency information for MIB installation on MIB browser / management software
Hope to help
Giuseppe
Marvin Rhoads Wed, 07/22/2009 - 05:25
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
As noted above, there is a Network Management forum under Network Infrastructure.
That said, Cisco publishes tables of supported devices for CiscoWorks at http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_device_support_tables_list.html
While the tables are only published for LMS 3.0, 3.1, and 3.2 (the latest three versions), even they do not support the Security and VPN devices (the sysObjectID you provided is for a Cisco ASA 5500 Series) under CiscoView and Campus Manager components. So, LMS 2.5 definitely does not.
Hope this helps.
