Jul 21st, 2009
Can the UC take 2 PRIs from the carrier, if the box is not being used from Data?
Steven DiStefano Tue, 07/21/2009 - 06:46
UC500 supports only Voice T1/E1. It doesn't support data T1/E1.
We give you an option of WAN connection through a fastethernet interface across which you can connect a cable modem, a dsl router, or even an ISR. You can connect to your SIP provider across the WAN link (through the fastethernet interface).
Depending on the UC500 model or SKU:
8, 16, 32 user SKU can use the expansion port to add a •VWIC2-1MFT-T1/E1  voice WIC.
UC500 48-user SKU is also available with integrated T1/E1 interface.
Hope this helps.
Steve D
brettboz28 Tue, 07/21/2009 - 06:52
OK so no matter what...The UC can only take 1 TDM PRI from the LEC
Related Content
