Setup MeetMe Conf Through CCA
jaydien1358
Level 3
Level 3
I enabled meetme conferenceing through CCA and assigned extension 777 for the service.
When I dial 777, I get a busy signal.
How can I troubleshoot this?
-Thanks.
-Brian
25 Replies 25
Hi Brian,
Check out the verification steps in this document:
https://supportforums.cisco.com/docs/DOC-9660
It has instructions on how to setup a meet me conference bridge.
Marcos
jaydien1358
Level 3
Level 3
I've already followed those verification steps. That is how I determined that the MeetMe bridge was not working. That is where I get the busy signal.
That document also has you map an FXO port to the MeetMe DN for the icomming dialplan. I cannot do that becuase the 4 FXO ports on this system are currently being used for POTS lines and are configured to forward the calls to the AA.
-Brian
Just to verify, you are hitting the meetme button first.
yes sir.
-Brian
Could you post your config?  Remember to remove passwords and other data you don't want to share.
ok. Here it is:
! Last configuration change at 11:57:38 GMT Tue Jul 21 2009 by admin
! NVRAM config last updated at 13:14:52 GMT Fri Jun 19 2009 by admin
version 12.4
parser config cache interface
no service pad
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname UC500-CUE
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-22.YB1
boot-end-marker
logging message-counter syslog
logging buffered 4096
enable secret 5 $1$TJDY$WvMaSfBy1v8fGjnelQKdj/
aaa new-model
aaa group server radius radius_local
server 192.168.10.1 auth-port 1812 acct-port 1813
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authentication login auth_method_radius_local group radius_local
aaa authorization exec default local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa accounting update periodic 10
aaa session-id common
clock timezone EST -5
clock summer-time GMT recurring
crypto pki trustpoint TP-self-signed-2325646731
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2325646731
revocation-check none
rsakeypair TP-self-signed-2325646731
crypto pki certificate chain TP-self-signed-2325646731
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32333235 36343637 3331301E 170D3039 30333137 30303132
  33375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33323536
  34363733 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B709 C830CCBC B0208AF0 10ACAD44 72677484 02464DDA B7B125E3 E9E4FDFC
  1D88E14A 287E7640 138C9BB0 F4568E05 DFF20CF6 E0FD1BEB A38EBC81 BF2A8B66
  4F500B8B 6A4FC3D7 E31678A6 B1CE5EC5 4DB0CE49 100FFAC4 19F7EC79 E9C5E376
  4E548366 38274367 8660B174 16B6F035 E5D12CC1 20999495 FE3C3781 9F139F7A
  A9F90203 010001A3 7A307830 0F060355 1D130101 FF040530 030101FF 30250603
  551D1104 1E301C82 1A554335 30302D43 55452E65 78636861 6E676530 372E6C6F
  63616C30 1F060355 1D230418 30168014 CC46F8A9 440F8A47 97EDF029 6F029612
  BC442730 301D0603 551D0E04 160414CC 46F8A944 0F8A4797 EDF0296F 029612BC
  44273030 0D06092A 864886F7 0D010104 05000381 81004B99 09D70ACD 48016131
  9EAE0BBE 571D3427 F85D4A3F 088E1BD8 C3EBD010 7A968AAD EF5DD849 4E722BD3
  E14D5F00 405B47C4 AB8EB2EA 79CFF44C 365A3962 A67D27D9 0A840949 3FD6D383
  05CA3D52 D315643A D47506B4 A821FF65 D89FBBF4 4585978C 8C4FD104 C83BB60E
  9A3A6FAB 6FBAA49A 6B80CDAE 04D31991 E5A856FD 5116
   quit
dot11 syslog
dot11 ssid Guest
vlan 2
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 03530859525876181E594C
dot11 ssid uc520-data
vlan 1
authentication open mac-address auth_method_radius_local
accounting acct_method_radius_local
dot11 ssid uc520-voice
vlan 100
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.20.1 192.168.20.224
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
   dns-server 192.168.10.2 192.168.10.8 4.2.2.1
   domain-name exchange07.local
   netbios-name-server 192.168.10.2 192.168.10.8
ip dhcp pool data
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip dhcp pool Guests
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
   dns-server 4.2.2.1
ip domain name exchange07.local
ip name-server 192.168.10.2
ip name-server 192.168.10.8
ip name-server 4.2.2.1
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
trunk group ALL_FXO
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice register global
max-dn 56
max-pool 14
voice translation-rule 1111
rule 15 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2222
rule 1 /^411/ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice-card 0
dspfarm
dsp services dspfarm
application
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
  param number-of-hunt-grps 10
  param queue-len 30
  param queue-cme-debugs 1
  param aa-hunt1 A109
username***********************
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key jaydien450886
dns 192.168.10.2 192.168.10.8
pool SDM_POOL_1
acl 101
max-users 10
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 5
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
crypto dynamic-map vpn_crypto_dymap 1
description Dynamic Crypto Map
crypto map vpn_crypto_map 65535 ipsec-isakmp dynamic vpn_crypto_dymap
archive
log config
  hidekeys
process-max-time 50
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
bridge irb
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
ip address 68.236.200.207 255.255.255.0
ip access-group 106 in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_LOW out
ip tcp adjust-mss 1300
duplex auto
speed auto
snmp trap ip verify drop-rate
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group$FW_INSIDE$
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
encryption vlan 2 mode ciphers tkip
ssid Guest
ssid uc520-data
ssid uc520-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
service-policy output Voice
interface Dot11Radio0/5/0.1
description Data Network - Mac Address Secured
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0/5/0.100
description Voice Network - Secured via RADIUS Authentication
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Virtual-Template5 type tunnel
ip unnumbered BVI1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
bridge-group 4
interface Vlan100
no ip address
bridge-group 100
interface BVI1
description VLAN1 - Data Network
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface BVI2
description VLAN2 - Guest Network
ip address 192.168.20.1 255.255.255.0
ip access-group 105 in
ip nat inside
interface BVI3
no ip address
interface BVI4
no ip address
interface BVI100
description VLAN100 - Voice Network
ip address 10.1.1.1 255.255.255.0
ip access-group 104 in
ip nat inside
ip local pool SDM_POOL_1 192.168.10.200 192.168.10.222
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 68.236.200.1
ip route 10.0.0.0 255.0.0.0 192.168.10.253
ip route 10.0.0.0 255.0.0.0 192.168.10.254 25
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip route 172.1.0.0 255.255.0.0 192.168.10.253
ip route 172.1.0.0 255.255.0.0 192.168.10.254 25
ip route 192.168.1.0 255.255.255.0 192.168.10.129
ip route 192.168.253.0 255.255.255.0 192.168.10.136
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/gui
ip nat inside source static tcp 192.168.10.6 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.10.2 443 interface FastEthernet0/0 443
ip nat inside source static tcp 192.168.10.2 25 interface FastEthernet0/0 25
ip nat inside source static tcp 192.168.10.99 3390 interface FastEthernet0/0 3390
ip nat inside source static tcp 192.168.10.110 11188 interface FastEthernet0/0 11188
ip nat inside source static tcp 192.168.10.110 3392 interface FastEthernet0/0 3392
ip nat inside source static tcp 192.168.10.6 3306 interface FastEthernet0/0 3306
ip nat inside source static tcp 192.168.10.6 21 interface FastEthernet0/0 21
ip nat inside source static tcp 192.168.10.6 20 interface FastEthernet0/0 20
ip nat inside source static tcp 192.168.10.4 5555 interface FastEthernet0/0 5555
ip nat inside source list 1 interface FastEthernet0/0 overload
logging dmvpn
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 23 permit 68.36.94.253
access-list 23 permit 192.168.10.0 0.0.0.255
access-list 100 permit ip any any
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
access-list 101 remark SDM_ACL Category=4
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip 10.0.0.0 0.255.255.255 any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 104 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark SDM_ACL Category=17
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 192.168.20.0 0.0.0.255 any
access-list 105 permit ip any any
access-list 106 permit udp any host 68.236.200.207 eq isakmp
access-list 106 permit udp any host 68.236.200.207 eq non500-isakmp
access-list 106 permit esp any host 68.236.200.207
access-list 106 remark SDM_ACL Category=17
access-list 106 permit tcp any host 68.236.200.207 eq 5555
access-list 106 permit tcp any host 68.236.200.207 eq ftp-data
access-list 106 permit tcp any host 68.236.200.207 eq 3306
access-list 106 permit tcp any host 68.236.200.207 eq telnet
access-list 106 permit tcp any host 68.236.200.207 eq 11188
access-list 106 permit tcp any host 68.236.200.207 eq 3390
access-list 106 permit tcp any host 68.236.200.207 eq smtp
access-list 106 permit tcp any host 68.236.200.207 eq 443
access-list 106 permit tcp any host 68.236.200.207 eq www
access-list 106 remark External Interface
access-list 106 permit tcp any host 68.236.200.207 eq 3392
ixi transport http
response size 64
no shutdown
request outstanding 1
ixi application cme
no shutdown
snmp-server community public RO
tftp-server flash:Core_2.cfg
tftp-server flash:/phones/7940_7960/P00308000500.sbn alias P00308000500.sbn
tftp-server flash:/phones/7940_7960/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/phones/7940_7960/P00308000500.loads alias P00308000500.loads
tftp-server flash:/ringtones/Pulse.raw alias Pulse.raw
tftp-server flash:/ringtones/24CTU.RAW alias 24ctu.raw
tftp-server flash:/PHONES/3951/BOOT3951.0-0-0-9.zz alias BOOT3951.0-0-0-9.zz
tftp-server flash:/PHONES/3951/DSP3951.0-0-0-2.zz alias DSP3951.0-0-0-2.zz
tftp-server flash:/PHONES/3951/SIP3951.8-1-2-0.zz alias SIP3951.8-1-2-0.zz
tftp-server flash:/PHONES/525/spa525g-7-1-3.bin alias spa525g-7-1-3.bin
tftp-server flash:/PHONES/7940_7960/P00308001000.loads alias P00308001000.loads
tftp-server flash:/PHONES/7940_7960/P00308001000.sb2 alias P00308001000.sb2
tftp-server flash:/PHONES/7940_7960/P00308001000.sbn alias P00308001000.sbn
tftp-server flash:/PHONES/525/spa525g-7-1-8.bin alias spa525g-7-1-8.bin
tftp-server flash:/PHONES/521_524/cp524g-08-01-15.bin alias cp524g-08-01-15.bin
tftp-server flash:/phones/3951/SIP3951.8-1-2.loads alias SIP3951.8-1-2.loads
tftp-server flash:/phones/521_524/cp524g-08-01-13.bin alias cp524g-08-01-13.bin
tftp-server flash:/phones/525/spa525g-7-1-7.bin alias spa525g-7-1-7.bin
tftp-server flash:/phones/7902/CP7902080002SCCP060817A.sbin alias CP7902080002SCCP060817A.sbin
tftp-server flash:/phones/7906_7911/apps11.8-3-4-16.sbn alias apps11.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-3-4-16.sbn alias cnu11.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-3-4-16.sbn alias cvm11sccp.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-3-4-16.sbn alias dsp11.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-3-4-16.sbn alias jar11sccp.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-3-5S.loads alias SCCP11.8-3-5S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:/phones/7915/B015-1-0-2.SBN alias B015-1-0-2.SBN
tftp-server flash:/phones/7916/B016-1-0-2.SBN alias B016-1-0-2.SBN
tftp-server flash:/phones/7921/APPS-1.2.1.SBN alias APPS-1.2.1.SBN
tftp-server flash:/phones/7921/CP7921G-1.2.1.LOADS alias CP7921G-1.2.1.LOADS
tftp-server flash:/phones/7921/GUI-1.2.1.SBN alias GUI-1.2.1.SBN
tftp-server flash:/phones/7921/SYS-1.2.1.SBN alias SYS-1.2.1.SBN
tftp-server flash:/phones/7921/TNUX-1.2.1.SBN alias TNUX-1.2.1.SBN
tftp-server flash:/phones/7921/TNUXR-1.2.1.SBN alias TNUXR-1.2.1.SBN
tftp-server flash:/phones/7921/WLAN-1.2.1.SBN alias WLAN-1.2.1.SBN
tftp-server flash:/phones/7925/APPSH-1.3.1.SBN alias APPSH-1.3.1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.1.LOADS alias CP7925G-1.3.1.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.1.SBN alias GUIH-1.3.1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.1.SBN alias SYSH-1.3.1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.1.SBN alias TNUXH-1.3.1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.1.SBN alias WLANH-1.3.1.SBN
tftp-server flash:/phones/7931/apps31.8-3-4-16.sbn alias apps31.8-3-4-16.sbn
tftp-server flash:/phones/7931/cnu31.8-3-4-16.sbn alias cnu31.8-3-4-16.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-3-4-16.sbn alias cvm31sccp.8-3-4-16.sbn
tftp-server flash:/phones/7931/dsp31.8-3-4-16.sbn alias dsp31.8-3-4-16.sbn
tftp-server flash:/phones/7931/jar31sccp.8-3-4-16.sbn alias jar31sccp.8-3-4-16.sbn
tftp-server flash:/phones/7931/SCCP31.8-3-5S.loads alias SCCP31.8-3-5S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-15-0.bin alias cmterm_7936.3-3-15-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-1-1-1.bin alias apps37sccp.1-1-1-1.bin
tftp-server flash:/phones/7940_7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:/phones/7941_7961/apps41.8-3-4-16.sbn alias apps41.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-3-4-16.sbn alias cnu41.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-3-4-16.sbn alias cvm41sccp.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-3-4-16.sbn alias dsp41.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-3-4-16.sbn alias jar41sccp.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-3-5S.loads alias SCCP41.8-3-5S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.8-3-4-16.sbn alias apps42.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-3-4-16.sbn alias cnu42.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-3-4-16.sbn alias cvm42sccp.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-3-4-16.sbn alias dsp42.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-3-4-16.sbn alias jar42sccp.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-3-5S.loads alias SCCP42.8-3-5S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.8-3-4-16.sbn alias apps70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-3-4-16.sbn alias cnu70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-3-4-16.sbn alias cvm70sccp.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-3-4-16.sbn alias dsp70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-3-4-16.sbn alias jar70sccp.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-3-5S.loads alias SCCP70.8-3-5S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.8-3-4-16.sbn alias apps75.8-3-4-16.sbn
tftp-server flash:/phones/7975/cnu75.8-3-4-16.sbn alias cnu75.8-3-4-16.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-3-4-16.sbn alias cvm75sccp.8-3-4-16.sbn
tftp-server flash:/phones/7975/dsp75.8-3-4-16.sbn alias dsp75.8-3-4-16.sbn
tftp-server flash:/phones/7975/jar75sccp.8-3-4-16.sbn alias jar75sccp.8-3-4-16.sbn
tftp-server flash:/phones/7975/SCCP75.8-3-5S.loads alias SCCP75.8-3-5S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7975/apps75.8-4-1-23.sbn alias apps75.8-4-1-23.sbn
tftp-server flash:/phones/7975/cnu75.8-4-1-23.sbn alias cnu75.8-4-1-23.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-4-1-23.sbn alias cvm75sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/dsp75.8-4-1-23.sbn alias dsp75.8-4-1-23.sbn
tftp-server flash:/phones/7975/jar75sccp.8-4-1-23.sbn alias jar75sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/SCCP75.8-4-2S.loads alias SCCP75.8-4-2S.loads
tftp-server flash:/phones/7970_7971/apps70.8-4-1-23.sbn alias apps70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-4-1-23.sbn alias cnu70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-4-1-23.sbn alias cvm70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-4-1-23.sbn alias dsp70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-4-1-23.sbn alias jar70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-4-2S.loads alias SCCP70.8-4-2S.loads
tftp-server flash:/phones/7945_7965/apps45.8-4-1-23.sbn alias apps45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-4-1-23.sbn alias cnu45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-4-1-23.sbn alias cvm45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-4-1-23.sbn alias dsp45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-4-1-23.sbn alias jar45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-4-2S.loads alias SCCP45.8-4-2S.loads
tftp-server flash:/phones/7942_7962/apps42.8-4-1-23.sbn alias apps42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-4-1-23.sbn alias cnu42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-4-1-23.sbn alias cvm42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-4-1-23.sbn alias dsp42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-4-1-23.sbn alias jar42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-4-2S.loads alias SCCP42.8-4-2S.loads
tftp-server flash:/phones/7941_7961/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:/phones/7940_7960/P00308001000.bin alias P00308001000.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-2-0.bin alias apps37sccp.1-3-2-0.bin
tftp-server flash:/phones/7936/cmterm_7936.3-3-16-0.bin alias cmterm_7936.3-3-16-0.bin
tftp-server flash:/phones/7931/apps31.8-4-1-23.sbn alias apps31.8-4-1-23.sbn
tftp-server flash:/phones/7931/cnu31.8-4-1-23.sbn alias cnu31.8-4-1-23.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-4-1-23.sbn alias cvm31sccp.8-4-1-23.sbn
tftp-server flash:/phones/7931/dsp31.8-4-1-23.sbn alias dsp31.8-4-1-23.sbn
tftp-server flash:/phones/7931/jar31sccp.8-4-1-23.sbn alias jar31sccp.8-4-1-23.sbn
tftp-server flash:/phones/7931/SCCP31.8-4-2S.loads alias SCCP31.8-4-2S.loads
tftp-server flash:/phones/7916/B016-1-0-3.SBN alias B016-1-0-3.SBN
tftp-server flash:/phones/7915/B015-1-0-3.SBN alias B015-1-0-3.SBN
tftp-server flash:/phones/7906_7911/apps11.8-4-1-23.sbn alias apps11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-4-1-23.sbn alias cnu11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-4-1-23.sbn alias cvm11sccp.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-4-1-23.sbn alias dsp11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-4-1-23.sbn alias jar11sccp.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-4-2S.loads alias SCCP11.8-4-2S.loads
tftp-server flash:/phones/525/spa525g-7-1-9.bin alias spa525g-7-1-9.bin
tftp-server flash:/phones/521_524/cp524g-8-1-16b.bin alias cp524g-8-1-16b.bin
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/Desktops/320x216x16/List.xml alias Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml alias Desktops/320x212x16/List.xml
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/phones/7945_7965/SCCP45.8-4-2S.loads alias SCCP45.SCCP45.8-4-2S.loads
radius-server local
nas 192.168.10.1 key 7 020C05420F0F0A2F
user 0019d24c6c01 nthash 7 1446402F2E20727C020B176C7037514E25200F7B087601592148410D0D0075010D mac-auth-only
user 001a921fcea3 nthash 7 065258736D1A513B5D44362F5B27737E747C6B627B4322305559010D7B700C5B22 mac-auth-only
user 0014a43b085a nthash 7 1536585D5073727D7F67177B40514157220F7D0E03772C5A41440E7E010101010D mac-auth-only
user 0022431cbe07 nthash 7 15445B59520B797709656C704752325759077B0E70725B224C410B080702020304 mac-auth-only
user 000cf15e077e nthash 7 08036E6B2D3F5644302F2A5C7A73067A6467723124445525037B0B76752C503C34 mac-auth-only
user 00243616f27a nthash 7 062758001E6C2A485745465E5C517278737A1066764A5332265602080101075E27 mac-auth-only
user 0013025df871 nthash 7 123F56424B2859277379060B1162063724415554057A0D03015C513A407F097276 mac-auth-only
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.10.1 auth-port 1812 acct-port 1813 key 7 070520554A001C0B
control-plane
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
bridge 4 protocol ieee
bridge 4 route ip
bridge 100 route ip
voice-port 0/0/0
station-id name Analog Phone
station-id number 301
caller-id enable
voice-port 0/0/1
timeouts ringing infinity
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
trunk-group ALL_FXO
connection plar opx 800
description Configured by CCA Auto Attendant
caller-id enable
voice-port 0/1/1
trunk-group ALL_FXO
caller-id enable
voice-port 0/1/2
trunk-group ALL_FXO
caller-id enable
voice-port 0/1/3
trunk-group ALL_FXO
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum sessions 2
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
associate application SCCP
dial-peer cor custom
name internal
name local
name domestic
name international
name local-plus
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-domestic
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member domestic
member local-plus
member national
member national-plus
member emergency
member toll-free
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 301
port 0/0/0
no sip-register
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 600
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 800
b2bua
codec g711ulaw
no vad
dial-peer voice 50 pots
description ** FXO pots dial-peer **-Emergency dial-peer
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 51 pots
preference 5
destination-pattern 911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 52 pots
corlist outgoing call-local
preference 5
destination-pattern 9[2-9]......
port 0/1/0
forward-digits 7
no sip-register
dial-peer voice 53 pots
corlist outgoing call-domestic
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/0
prefix 1
no sip-register
dial-peer voice 54 pots
corlist outgoing call-international
preference 5
destination-pattern 9011T
port 0/1/0
prefix 011
no sip-register
dial-peer voice 55 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 56 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 57 pots
preference 5
port 0/1/1
forward-digits 7
no sip-register
dial-peer voice 58 pots
preference 5
port 0/1/1
prefix 1
no sip-register
dial-peer voice 59 pots
preference 5
port 0/1/1
prefix 011
no sip-register
dial-peer voice 60 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 61 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 62 pots
preference 5
port 0/1/2
forward-digits 7
no sip-register
dial-peer voice 63 pots
preference 5
port 0/1/2
prefix 1
no sip-register
dial-peer voice 64 pots
preference 5
port 0/1/2
prefix 011
no sip-register
dial-peer voice 65 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 66 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 67 pots
preference 5
port 0/1/3
forward-digits 7
no sip-register
dial-peer voice 68 pots
preference 5
port 0/1/3
prefix 1
no sip-register
dial-peer voice 69 pots
preference 5
port 0/1/3
prefix 011
no sip-register
dial-peer voice 2010 voip
description Prompt Management Dial Peer
destination-pattern 477
b2bua
codec g711ulaw
no vad
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
authentication credential cisco cisco
em logout 0:0 0:0 0:0
xml user weex password weex-pw 15
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
timeouts interdigit 7
system message Jaydien Network Solutions
url services http://192.168.10.6/ciscoipphone/xmlfeed.xml
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 7914 S00105000300
load 7915-12 B015-1-0-2
load 7915-24 B015-1-0-2
load 7916-12 B016-1-0-2
load 7916-24 B016-1-0-2
load 7902 CP7902080002SCCP060817A
load 7906 SCCP11.8-3-5S
load 7911 SCCP11.8-3-5S
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-3-5S
load 7936 cmterm_7936.3-3-15-0
load 7937 apps37sccp.1-1-1-1
load 7960-7940 P00308000500
load 7941 SCCP41.8-3-5S
load 7941GE SCCP41.8-3-5S
load 7942 SCCP42.8-3-5S
load 7945 SCCP45.8-3-5S
load 7961 SCCP41.8-3-5S
load 7961GE SCCP41.8-3-5S
load 7962 SCCP42.8-3-5S
load 7965 SCCP45.8-4-2S
load 7970 SCCP70.8-3-5S
load 7971 SCCP70.8-3-5S
load 7975 SCCP75.8-3-5S
load 521G-524G cp524g-08-01-13
load 525G spa525g-7-1-7
time-zone 12
live-record 700
voicemail 600
max-conferences 1 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group report url prefix tftp://192.168.10.99
hunt-group report url suffix 0 to 1
hunt-group report every 1 hours
moh flash:/media/Unified_Communications.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 8.T
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
night-service date May 25 00:00 23:59
night-service date Jul 4 00:00 23:59
night-service date Sep 7 00:00 23:59
night-service date Oct 12 00:00 23:59
night-service date Nov 11 00:00 23:59
night-service date Nov 26 00:00 23:59
night-service date Dec 25 00:00 23:59
create cnf-files version-stamp 7960 Jul 21 2009 11:40:07
ephone-dn-template  1
ephone-template  15
url services 1 http://10.1.10.1/WebExPhone/MainMenu WebEx-Meetings
url services 2 http://10.1.10.1/timecardview/common/login.do TimeCardView
softkeys idle  Redial Newcall Mobility Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected  Hold Endcall Mobility Trnsfer LiveRcd Confrn ConfList RmLstC Acct Park
ephone-template  16
softkeys hold  Newcall Resume Select Join
softkeys idle  Redial Dnd Mobility Pickup Cfwdall Newcall Gpickup
softkeys seized  Redial Pickup Meetme Gpickup HLog Endcall
softkeys connected  Hold LiveRcd Trnsfer Confrn ConfList RmLstC Mobility Endcall Acct Park
ephone-dn  1
number 300 no-reg primary
label Page All Phones
description Global Paging Group
name IP-Paging1
paging ip 239.1.1.1 port 2000
ephone-dn  5  dual-line
number 301 no-reg primary
label 301
description Analog Extension
name Analog Extension
call-forward busy 600
call-forward noan 600 timeout 10
ephone-dn  6  dual-line
number 302 no-reg primary
label 302
description fxs FXS
name fxs FXS
ephone-dn  7  dual-line
number 303 no-reg primary
label 303
description fxs FXS
name fxs FXS
ephone-dn  8  dual-line
number 304 no-reg primary
label 304
description fxs FXS
name fxs FXS
ephone-dn  9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn  10  dual-line
number 104 no-reg primary
pickup-group 1
label 104
description Mathew Powell
name Mathew Powell
snr 919732164242 delay 5 timeout 30 cfwd-noan 600
ephone-dn  11  dual-line
number 107 no-reg primary
pickup-group 1
label 107
description Marissa Frew
name Marissa Frew
ephone-dn  12  dual-line
number 103 no-reg primary
pickup-group 1
label 103
description Receptionist Desk
name Receptionist Desk
ephone-dn  13  dual-line
number 101 no-reg primary
pickup-group 1
label 101
description Brian Fleishman
name Brian Fleishman
call-forward noan 600 timeout 20
ephone-dn  14  dual-line
number 105 no-reg primary
pickup-group 1
label 105
description Richard LeTrent
name Richard LeTrent
mobility
ephone-dn  15  dual-line
number 206 no-reg primary
pickup-group 1
label 206
description Test Phone
name Test Phone
ephone-dn  18  dual-line
number 209 no-reg primary
pickup-group 1
label 209
description Brian SoftPhone
name Brian SoftPhone
ephone-dn  20
number 108
label Support Desk
description Support Desk Mailbox
name Support Desk
call-forward all 600
hold-alert 30 originator
ephone-dn  30
number 1101
label Internal
description Intercom - Brian
name Intercom - Brian
intercom 1101 barge-in no-mute
ephone-dn  31
number 1107
label Internal
description Intercom - Marissa
name Intercom - Marissa
intercom 1107 barge-in no-mute
ephone-dn  32
number 1104
label Internal
description Intercom - Matthew
name Intercom - Matthew
intercom 1104 barge-in no-mute
ephone-dn  33
number 1103
label Internal
description Intercom - Receptionist
name Intercom - Receptionist
intercom 1103 barge-in no-mute
ephone-dn  34
number 1105
label Internal
description Intercom - Richard
name Intercom - Richard
intercom 1105 barge-in no-mute
ephone-dn  35
number 1206
label Internal
description Intercom - Test Phone
name Intercom - Test Phone
intercom 1206 barge-in no-mute
ephone-dn  49
number 704 no-reg primary
park-slot
ephone-dn  50
number 703 no-reg primary
park-slot
ephone-dn  51
number 702 no-reg primary
park-slot
ephone-dn  52
number 701 no-reg primary
park-slot
ephone-dn  53  octo-line
number 777 no-reg primary
conference meetme
ephone-dn  54  octo-line
number C001 no-reg primary
conference ad-hoc
ephone-dn  55
number A801... no-reg primary
mwi off
ephone-dn  56
number A800... no-reg primary
mwi on
ephone  2
device-security-mode none
video
mac-address C58D.EAE4.0001
ephone-template 16
max-calls-per-button 2
username "a2" password 1234
type anl
button  1:6
ephone  3
video
mac-address C58D.EAE4.0002
ephone-template 16
username "a3" password 1234
type anl
button  1:7
ephone  4
video
mac-address C58D.EAE4.0003
ephone-template 16
username "a4" password 1234
type anl
button  1:8
ephone  5
conference admin
video
mac-address 0003.6B8B.0C81
ephone-template 16
speed-dial 1 1 label "Intercom An Extension"
speed-dial 2 300 label "Page All Phones"
paging-dn 1
type 7960
button  1c11,31
ephone  6
conference admin
video
mac-address 0023.339B.A9A7
ephone-template 16
paging-dn 1
type 7965
button  1c10,32
ephone  7
video
mac-address 000D.65EC.C591
ephone-template 16
fastdial 1 917322448111 name OCBR
fastdial 2 917328405900 name Starkey - Brick
fastdial 3 917322403600 name Starkey - TR
fastdial 4 917327933339 name Birchler - Ortley
fastdial 5 917327933333 name Birchler - Lavallette
fastdial 6 917329229292 name Mazza
fastdial 7 917324466100 name Reiss
paging-dn 1
type 7960
button  1c12,33
ephone  9
video
mac-address 0023.339B.D6BE
ephone-template 16
paging-dn 1
type 7960
button  1c14,34
ephone  11
video
mac-address 000C.F15E.077E
ephone-template 16
paging-dn 1
mtp
type CIPC
button  1c13,20
ephone  12
conference admin
video
mac-address 0023.331B.DA23
ephone-template 16
paging-dn 1
type 7965
button  1c13,30 2:11
ephone  14
video
mac-address 001D.0911.169A
ephone-template 16
paging-dn 1
mtp
type CIPC
button  1c15,35
ephone-hunt 1 longest-idle
pilot 106
list 103, 101, 105
final 108
timeout 16, 16, 16
no-reg pilot
statistics collect
description Support Desk Hunt Group
ephone-hunt 50 longest-idle
pilot A109
list 302
timeout 8
statistics collect
auto logout 10
description *** CCA BACD ***
display-logout All agents logged out
ephone-hunt 51 sequential
statistics collect
ephone-hunt 52 sequential
statistics collect
ephone-hunt 53 sequential
statistics collect
ephone-hunt 54 sequential
statistics collect
ephone-hunt 55 sequential
statistics collect
ephone-hunt 56 sequential
statistics collect
ephone-hunt 57 sequential
statistics collect
ephone-hunt 58 sequential
statistics collect
ephone-hunt 59 sequential
statistics collect
banner motd
This router belongs to Jaydien Network Solutions, LLC.
Unauthorized logins are restricted.
P.S. Microsoft sucks.
line con 0
exec-timeout 30 0
password 7 0104570A5F5B111C
logging synchronous
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
exec-timeout 30 0
logging synchronous level all
line vty 5
access-class 23 in
password 7 1400430508543D38
line vty 6 100
access-class 23 in
logging synchronous
exception data-corruption buffer truncate
ntp logging
ntp update-calendar
ntp server 192.168.10.2
ntp server tock.usno.navy.mil prefer
end
Configuration looks fine. Are you trying to initiate the conference from ephone 12? That is the only one designated as conference admin... Try to add that command to the other ephones.
Marcos
Yes I am. I added conference admin to two other phones (ephone 5/6), and no luck. Get a busy signal after hitting meetme and then ext 777.
-Brian
Should the MeetMe extension show up in CUE GUI as a MWI extension? That is how it is appearing on my system.
-Brian
No, it shouldn't. Do you think you might have a diaplan conflict?
Marcos
Sounds like it may be. I will start investigating.
-Brian
My dial-plan looks ok.
Nothing seems to be interfering that would cause extensions starting with '7' not to work. I did just test my park slots as well as they aslo begin with the digit '7' and I am getting a busy signal as well.
Now I'm really puzzled.
-Brian
Let's check a couple more things before we get TAC involved. Can you send the following:
show sccp
show dspfarm all
Marcos
Show SCCP:
UC500-CUE#sh sccp
SCCP Admin State: UP
Gateway Local Interface: Loopback0
        IPv4 Address: 10.1.10.2
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.1.1, Port Number: 2000
                Priority: N/A, Version: 4.0, Identifier: 1
                Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: SOCKET_OPEN_FAILED
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
Show DSPFARM:
UC500-CUE#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description : DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP   Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    2   23.8.1   UP     N/A  FREE  conf   1      -         -         -
Total number of DSPFARM DSP channel(s) 2
