Importing MAC filters from a file; what's the format?
Jul 21st, 2009
I need to set up MAC authentication for a bunch of systems. I'd like to import the data from a file as there are quite a few of them, but I can't seem to get the format correct for the import file.
Is this documented somewhere? Or does anyone know what the correct format is?
Thanks!
Lynne
I tried setting it up the way it displays in the 'show macfilter summary' controller commnad, but that didn't work
Lucien Avramov Tue, 07/21/2009 - 19:18
  • Red, 2250 points or more
Create a .csv file with the following format:
MAC-ADDRESS,SSID,INTERFACE,DESCRIPTION
etc...
Configure>Controller Templates>Security>MAC Filtering>Add
Choose the file and submit.
Trending Topics - Security & Network
