Terminal Server
Jul 21st, 2009
All the devices, including Cisco routers and switches, sun servers are connected to the terminal server, and we are able to login through the terminal server, but We have a NetApps server FAS3040 connected to the Cisco terminal server and we are not able to login it. If we connect the laptop to the NetApps server through the Cisco blue console cable, we are able to login from the Hype terminal.We have changed to different cables (straight or crossover), DB 9 terminator on the NetApps server, but no luck. We are wondering it may be the pinout issue, but it is not sucessful. Does anyone know about this? Please advise.
Here is the part of the Cisco terminal server configuration.
line 97 112
exec-timeout 15 0
password cisco
transport input all
stopbits 1
Please advise.
wonderpug Thu, 10/22/2009 - 07:43
I have the same issue here. Terminal server is sending garbish characters to my server once its connected. Does anyone have any idea where I should nail it down the problem? Thanks!
Richard Burts Thu, 10/22/2009 - 08:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
tary
Giberish characters being displayed is typically the symptom of mismatched speed setting. Can you verify what speed the server is expecting? If so you should configure the speed of that line in the term server to match what is expected by the server.
Rick
wonderpug Wed, 11/11/2009 - 07:05
Moving to different port I am able to solve this issue. But now it always returns "disconnect by forein host". I have a feeling. The port number is not match with the cable that connect to the card. Is there anyway i can verify that?
