signal vs. signal-update...
Jul 21st, 2009
I occasionally get DTMF tones from my carrier in a signal-update vs. a signal. When my AS5400 receives these messages I send back a 400 Bad Request. I have tried to change my dial-peer to dtmf-relay h245 signal but it didn't help. Anyone know how I should handle these occasional SIP messages? TIA.
Nicholas Matthews Tue, 07/21/2009 - 09:34
  • Red, 2250 points or more
I'm confused because:
h245-signal and signal-update are H323 messages.
400 Bad Request is a SIP message.
Every signal should be followed up by a signal-update to mark the end of the digit, but that is for an H323 call.
Can you explain the call flow more?
-nick
snickered Tue, 07/21/2009 - 10:12
Exactly. I'm getting signal-update in a SIP INFO message from my carrier. I have a simple setup. Just doing SIP->TDM. Calls that don't have this signal-update message work fine with 'dtmf-relay cisco-rtp'. I'm wondering if there's a way to handle these types of messages or if I need to tell my carrier to get their act together. ;)
INFO sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP yyy.yyy.yyy.yyy:5060;branch=z9hG4bK0dBea481531b543eab1
From: "Cell Phone TX" [email protected];isup-oli=62;pstn-params=808482808882>;tag=gK0d5bb22f
To: [email protected]>;tag=213985C4-414
Call-ID: [email protected]
CSeq: 30593 INFO
Max-Forwards: 70
Supported: 100rel
Content-Length: 33
Content-Type: application/dtmf-relay
Signal-Update= 8
Duration= 325
Nicholas Matthews Tue, 07/21/2009 - 10:38
There isn't going to be anything on the gateway to support this. Just looked up the spec that we use, and we're looking for signal= .
If you can, have them update that field and you'll be alright. Otherwise ask for RFC 2833 as it is more of a SIP standard for DTMF than it is for anything else.
-nick
snickered Tue, 07/21/2009 - 11:05
My carrier told me that I need to allow for signal-update or just discard it. Is there a way I can discard these?
Nicholas Matthews Tue, 07/21/2009 - 11:20
The only option that may get you this is a new feature in 12.4(22)YB:
voice service voip
sip
pass-thru content unsupp
I have my doubts about this, so you will probably need to push back on the provider.
Considering that an INFO message requires a response, ignoring it isn't an option.
-nick
