Sticky Resource Not Available when setting up sticky http-cookie
rlortiz
When I try to configure the sticky:
(config)# sticky http-cookie ACE-COOKIE COOKIE-STICKY
I get the error:
sticky resource not available
An L7 policy has not yet been set up… could that be the reason for this error? Or, is it because I have not setup a class resource for the sticky cookie?
You got it right.
You need to create a resource class for sticky and apply it to the desired context to make it work.
resource-class xyz
limit-resource sticky minimum 10.00 maximum unlimited
context test
allocate-interface vlan 10
allocate-interface vlan 11
member xyz
Syed
You got it right.
resource-class xyz
context test
member xyz
Syed
Syed,
I thought it resolved it, but it really didn't.
Added the resource-class in the Admin context:
resource-class any-available
limit-resource all minimum 0.00 maximum unlimited
limit-resource sticky minimum 35.00 maximum equal-to-min
no difference.
Did you assign it to the admin context?
Do you have following in your config?
context Admin
member any-available
Syed Iftekhar Ahmed
There was a misspelling..all better now..
Thanks again Syed!!
