Jonathan Schulenberg Thu, 07/23/2009 - 05:57
  • Cisco Designated VIP,
    2017 IP Telephony
Is this CCX or CCE?
What version are you upgrade from and to?
Is the user a local administrator of that PC?
Is there a firewall, ACL, NAT, or anything restricting communications between that PC and the server?
Is this happening on every PC or just this one?
marcoriosbazan Thu, 07/23/2009 - 06:15
->is the CCX..
->when i change the desktop of the agent (adding a button), and CAD software tries to update the client version ..
then I get this error message ..
->yes is the local admin
->no nothing between
->on every PC..
kraghavansag Fri, 07/24/2009 - 01:08
I think I have seen this happen in a WAN connectivity where there were huge packet drops between the server and agent desktop. is the agent on the LAN where the server is?
kraghavansag Fri, 07/24/2009 - 09:22
can you check and see if you find anything in the logs for CAD software? location : C:\Program Files\Cisco\Desktop\log . you may want to check the one which says agent0001.log after you try to open the CAD.
clarkjaso Fri, 07/24/2009 - 10:55
How about trying to put your UCCX server name in the host file of the PC, then try.
marcoriosbazan Mon, 07/27/2009 - 03:45
it is possible that this application depends on the version of Internet Explorer or another patch, to interpret the script . pac?
