NAT/PAT Question on PIX 545-
Answered Question
Jul 21st, 2009
Urgent help needed please!
Setting up a PAT statement for eg;
static (inside,dmz) tcp interface 8002 10.144.100.92 8000 netmask 255.255.255.255
When configuring this through ASDM on a Cisco pix the ASDM asks for the Original port number and then the Translate to port number.
Which perspective does the "Original" term come from?
1) The Original port of the Application on the Server supplying the service - ie The port on the inside server you are translating from?
*** Or ***
2)From the perspective of an incoming packet from an external source - ie The port number that is original in the destination field "before" it gets translated to the actual port that hosts the service on the inside server?
By looking at it in these two perspectives it can be either?
Any help is much needed and would be very much appreciated.
Thank you.
Correct Answer by Roman Rodichev about 8 years 1 week ago
original = real = inside = local = 8000
foreign = mapped = dmz = translate to = 8002
edit: my bad, I flipped the ports from the first post
Overall Rating: 5 (1 ratings)
Correct Answer
Roman Rodichev Tue, 07/21/2009 - 11:46
  • Gold, 750 points or more
