Help with Design
Jul 21st, 2009
I need to install a CAM/CAS at remote site. We will be utilizing the NAC for wireless and wired devices. The environment is a learning center which will utilize VLANs. It would appear that in-band offers the most comprehensive security and control. In regards to the mode - what considerations would you make between choosing between real or virtual gateway? We plan on having seperate VLANs for students and instructors.
vmoopeung Mon, 07/27/2009 - 11:32
The CAS configured as a virtual gateway acts like a bridge for the managed network. The virtual gateway configuration is good when managed clients share a subnet with trusted clients and you do not want to modify the existing gateway or architecture. There is no need to define static routes on any of the routing devices.
http://www.cisco.com/en/US/products/ps6128/products_configuration_example09186a008074d641.shtml#intro
