Anyconnect / Can't reach DMZ
Jul 21st, 2009
I have Anyconnect configured and working on an ASA that also houses the DMZ.
I can reach the entire network from behind the Anyconnect except for the DMZ. Is there something additional that needs to be configured?
I checked to make sure I wasn't NATing the traffic and there are no ACL's blocking me and the DMZ is in my tunneled routes (I can ping the DMZ interface on the ASA); it just won't send traffic.
Roman Rodichev Tue, 07/21/2009 - 21:22
are you sure it's not natting?
do you have:
nat (dmz) 0 access-list ACL
and ACL should permit source DMZ_SUBNET destination VPN_POOL_SUBNET
can you post:
sh run nat
sh run access-group
sh run access-list
*** don't post outside_int_inbound ACL :)
BrianMitchellTX Wed, 07/22/2009 - 07:38
Thank you for the reply...yep it was indeed a NAT issue.
I went to post the config you asked for and when I did a sho run nat I saw I had:
nat (Inside) 0 access-list NONAT
nat (Inside) 1
nat (DMZ) 1
I made the correct entries in the NONAT acl but I didn't have a nat (DMZ) 0 statement. Once I added that I was able to get to the DMZ.
Thanks again, your request actually led me to the correct solution.
