Cleared config now wont connect to PDM
Jul 21st, 2009
I cleared the config on my pix 515e and 525 and it now comes up with this error in firefox:
ssl error no cipher overlap
I think I did something with the SSL key so now it wont load the PDM.
Any suggestions?
Collin Clark Wed, 07/22/2009 - 05:24
You need to enable http, an IP that can connect to http and you have to tell the firewall where the ASDM image is.
http server enable
http server idle-timeout 10
http 10.1.2.17 255.255.255.255 inside
asdm image disk0:/asdm-621.bin
To recreate your SSH Keys-
https://packetpros.com/cisco_kb/ASA_SSH.html
Hope that helps.
m-jankowski Wed, 07/22/2009 - 18:51
Didn't work.. same message when trying to access PDM from correct IP address.
CSCO11167812 Thu, 07/23/2009 - 05:56
Probably you have a certificate problem.
Did you try to remove the certificate in Firefox.
HtH
Michel
m-jankowski Fri, 07/24/2009 - 15:06
IE gives a page cannot be displayed error.
It isn't a problem with the browser.. I'm using three different machines. None work.
Richard Burts Sat, 07/25/2009 - 10:57
Michael
I am guessing that there is some issue with what you put into the config of the PIXes. Can you post the config?
Rick
m-jankowski Sun, 07/26/2009 - 15:29
I'll get it posted in a bit however they are all default settings with only the HTTP server enabled for 192.168.1.0 for access.
I can get as far as waiting for the PDM to load if I disable SSL3 but it still hangs.
Yes I have an earlier version of Java not update 14.
m-jankowski Sun, 07/26/2009 - 15:56
: Saved
: Written by enable_15 at 19:46:14.673 UTC Sun Jul 26 2009
PIX Version 6.3(4)
interface ethernet0 auto shutdown
interface ethernet1 auto
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
nameif ethernet3 intf3 security6
nameif ethernet4 intf4 security8
nameif ethernet5 intf5 security10
enable password NuLKvvWGg.x9HEKO encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pix
domain-name network.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
no ip address outside
ip address inside 192.168.1.1 255.255.255.0
no ip address intf2
no ip address intf3
no ip address intf4
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address intf2
no failover ip address intf3
no failover ip address intf4
no failover ip address intf5
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.10-192.168.1.20 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Cryptochecksum:f470fb4cd139237cac907debf736a86d
Richard Burts Sun, 07/26/2009 - 17:05
Michael
Thanks for posting the config. I believe that if you take a close look at the fourth octet of your permit for http that you will see what your problem is:
your permit is for a host specific address (and there is almost certainly not a host in the network with address 192.168.1.0). If you change the mask to 255.255.255.0 then I believe that your access via PDM will work.
Rick
m-jankowski Sun, 07/26/2009 - 17:32
Changed it. Still nothing. Keeps giving me the cypher overlap problem.
m-jankowski Sat, 08/01/2009 - 15:10
Surely someone here knows what the issue is?
If not do they still sell support for the PIX line? If so, where can I purchase a contract?
davy.timmermans Wed, 08/05/2009 - 12:03
I never worked with a PIX or similar product but I found this on the web:
hen you attempt to access PDM, the message "the page cannot be displayed" appears in Internet Explorer or the message "network connection was refused by the server" appears in Netscape Communicator.
1. Check that you are using "https" in your connection to "https://pix_inside_interface_
ip_address" and not "http." The connection cannot be made using "http," it must be "https."
2. If you cannot connect, enter the show version command to check that you have the proper activation key to use DES or 3DES. If you do not, obtain an activation key that supports this requirement before continuing. If, after confirming that your activation key supports using DES or 3DES
http://www.cisco.com/en/US/docs/security/pix/pix63/pdm30/installation/guide/pdm30CH5.html
