Cisco Unity
Jul 21st, 2009
Hii,
When I tried to open the integration manger in cisco unity 4.0 i got this message.
"Failed loading the MiuRegistry component Error 0x80070005. Access denied.
In order to use the Telephony Integration Manager your Windows account must
be a Cisco Unity Administrator and a member of the Adminstrators group on
this computer.
Please Help!
Jaime Valencia Wed, 07/22/2009 - 03:33
  • Cisco Employee,
  • Hall of Fame,
    2011
Which account are you using to log in???
You should be using UnityAdmin or its equivalent if you created another one.
The error already explains is a permissions issue so check what it tells you: the account is a Unity Admin and it's part of the Administrators group
java
if this helps, please rate
amarmn1975 Wed, 07/22/2009 - 19:56
Hii,,
I allready use the UnityAdmin accoun, it was working , but i dont know what happend to it.
