ASA5510 as default gateway problem
Jul 21st, 2009
Hi everybody!
I have an ASA5510 with an "inside" and "outside" topology.
All users at network are using the ASA to reach Internet.
Now I have a new router in the inside.
The problem is users cannot reach network at the new router.
I was looking for some configuration examples and I found "same-security-traffic permit intra-interface" command. It did not help me at all. Not sure if this command is available only for VPN connections.
I attached the LAN drawing.
Any idea?
Thank you everybody!
Overall Rating: 5 (1 ratings)
You are trying to make the ASA act as a router for the network - when you have a perfectly good router to perform that function, my reccomendation is:-
1) Have all servers/desktops iin the point to the router as the default gateway.
2) Have a static default route in the router pointing to the ASA for internet traffic.
3) Have a route in the ASA for the network pointing to the IP of the router.
This will fix all your issues - and correct your topology.
