WAAS Mobile
Jul 22nd, 2009
Does anyone else experience issues with other applications not working when using waas mobile. We have issues (on both XP & Vista laptops) where outlook intermittantly disconnects, drive mappings are broken, windows explorer hangs when trying to open local folders, other apps just don't work. If the user disables the waas client, then all is working. So has anyone else experienced this? We are running Version: 3.4.2.1676
ldardon Tue, 07/28/2009 - 06:01
If you are running any virus scanner then uninstall it. And also make sure the firewall is disabled or not. Ensure enough memory is available. Verify Delta Cache utilization and CPU utilization.
