How to set break Hours greetings with Unity Connection 7.0
tka
Hi all,
I would like to set set up a Break Hours greetings (closed hours and wek-ends) to a Unitu Connection 7.0 Call Handler. I can't see exactly where/how to do that.
any help please.
Jaime Valencia
Configure the schedule, when you set it as open you'll play std greeting, when closed, closed greeting.
For further explanation you can use the help -> for this page
java
if this helps, please rate
java
Jaime Valencia
java
java
