SDK for PVC300 and PVC2300?
Jul 22nd, 2009
Hi, I'm wondering where can I find some information about how to externally use some functions ofthose cameras.
By externally I mean by my own software. I'm particularly interested in PTZ and digital I/O. The best would be http queries. Is there any CGI reference for Cisco products?
I also wonder if there is any way to get some configuration data (for example FPS that is set) by other means than by analysing camera web page?
Overall Rating: 0 (1 ratings)
doishi Wed, 07/22/2009 - 09:54
The APIs for the Cisco Small Business cameras are posted in Partner Central.  From Cisco.com click on Partner Central, Log in is required.  Search for PVC2300 API.  It is a technical resource document so make sure you are on the right tab.  APIs for PVC300 and WVC210 are also available in the same place.
streaves Mon, 09/27/2010 - 09:24
Hi DJ -- We are in the process of publishing the APIs in the Cisco Software Center to make download easier. I'll update the thread as soon as they're available.
Stephanie
Dirk-Jan Uitten... Mon, 09/27/2010 - 09:28
Great! And thank you for the super fast response. One comment on the old API: this was an .exe you had to install which basically did nothing more than extract a ZIP file. Hope that this will change so people can just download a ZIP file which makes it multi-platform (OSX, Linux etc).
Cheers
DJ
Related Content
