Impersonation of AP issue
Answered Question
Jul 22nd, 2009
i have a WISM with release 6.0 and 150 AP connected all in the same RRM. In the TrapLog I see a lot of |"Impersonation of AP......" messages. This issue is between AP connected to the same WISM and in he same RRM.
Any idea?
Giovanni
An
Correct Answer by Roman Rodichev about 7 years 9 months ago
Do you have "AP Authentication" enabled under Security>WPS>APAuth/MFP ? If you do, try disabling it (on both controllers)
Roman
Overall Rating: 5 (1 ratings)
Roman Rodichev Wed, 07/22/2009 - 05:44
  • Gold, 750 points or more
Do you have "Validate SSID" checked under WLC > Security > Wireless Protection Services > Trusted AP Policies?
gbressanin Wed, 07/22/2009 - 07:26
In my WISM with revision 6.0 installed I don't find the "Trusted AP Policies" under "Wireless Protection Services".
I attach the copy of the security web page.
Bye
Giovanni
Roman Rodichev Wed, 07/22/2009 - 11:42
Is this happening for one specific AP or for many of them?
Correct Answer
Roman Rodichev Wed, 07/22/2009 - 22:36
Roman
gbressanin Thu, 07/23/2009 - 06:20
Hi Roman,
thank you, it was the " AP Authentication Policy" configured as "AP Authentication that generate the error messages. Now I set the Protection Type to " Management Frame Protection" and I not get any error messages.
Thank you again.
Giovanni
Roman Rodichev Thu, 07/23/2009 - 12:59
Giovanni,
Interesting, that means:
1. Your two controllers don't have matching RF Group names. Double-check.
2. or you could be running into a bug
MFP is definitely a better option :)
Roman
gbressanin Fri, 08/07/2009 - 03:22
Hi Roman,
sorry for the late but I'm in vacation. I read now the answer at the case that I opened to the TAC about this issue.
From the case notes which you have added, I can see that you are affected by the bug:
CSCsi18369
AP Auth: Known rogues are reported as impersonation alerts
Symptom:
If AP authentication is enabled, the controller will report the entries in the known AP MAC address
list, as impersonation alerts.
Workaround:
Use MFP or disable AP Authentication
Giovanni
Trending Topics - Security & Network
