unable to add IMAP access to Voice Messages in Unity Connection 7.0
Answered Question
Jul 22nd, 2009
Hi all,
WHen trying to add IMAP external service, I can't see the IMAP entry in the service TYPE combolist.
Is there any config to do to enable that or any specific licence to add ?
best regards,
Correct Answer by seckid about 8 years 2 days ago
definitely make sure you have the licensing, but also make sure that you have turned on imap in the class of service for the users you want to have it. I chased that problem and not even TAC could find it. They thought it was a licensing issue. I happened to fix it myself by going through every menu and line item and finding it.
Its in:
Class Of Service
(your users' COS)
Licensed Features
Allow Users to Access Voice Mail Using an IMAP Client
Overall Rating: 4.8 (5 ratings)
Jaime Valencia Wed, 07/22/2009 - 03:29
  • Cisco Employee,
  • Hall of Fame,
    2011
AFAIK you need advanced licensing users to get IMAP and ASR, you can go to your licensing page to see details of licenses you have
java
if this helps, please rate
Rob Huffman Wed, 07/22/2009 - 05:06
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ramzi,
Java is most correct here (+5 points my friend :)
You should see a line like this in your license file;
INCREMENT LicIMAPSubscribersMax cisco 7.0 permanent xxxx \
Where xxxx = the number of users licensed for IMAP access.
Hope this helps!
Rob
Correct Answer
seckid Wed, 07/22/2009 - 05:20
Its in:
Class Of Service
(your users' COS)
Licensed Features
