MGCP, Call Manager , Voice Gateway questions
wilson_1234_2
Level 3
Level 3
In a scenario of
Main Branch has Call Manager controlling Main Site and branch phone functions.
Branch sites have voice gateways connected to Main site via MPLS with IP Phones for branch users and configured with MGCP.
Each branch has a PRI for ouside local and LD calls.
Questions:
The voice gateway, when configured with MGCP is a remote control mechanism for call manger to have control of all ports on the gateway, correct?
When configured this way, and the remote sites have their own PRI, is considered PRI Backhauling?
Do the remote branch phones register with Call Manger or the remote gateway ?
Does the remote gateway notify Call Manager that a phone is taken of hook, or the phone does it directly?
When a call comes in to a remote branch via the branch PRI, would the process be:
1. Call hits remote gateway
2. Remote gateway contacts Call Manager via MGCP.
What does MGCP do at this point?
3. Call data is carried via tcp port 2428 from Branch gateway to Call Manager.
4. Call Manager communicates vi skinny with remote phone.
11 Replies 11
Jaime Valencia
I strongly recommend you to start reading documentation from http://www.cisco.com to understand how things work.
Questions:
A: MGCP is ALWAYS a master-slave protocol independently of LAN/WAN
A: MGCP ALWAYS backhauls Q931 info to CUCM
A: With the call control agent, CUCM.
Does the remote gateway notify Call Manager that a phone is taken off hook, or the phone does it directly?
A: NO, SCCP is between CUCM and phones
A: Handles Q921 and backhauls Q931 to CUCM to determine routing based on IEs.
4. Call Manager communicates via skinny with remote phone.
Again, you need to read documentation to understand the differences between a call agent, a GW, a phone and how the communications and protocols are handled between them.
java
if this helps, please rate
java
Is there any documentation that shows the call flows and answers the questions I have here:
"differences between a call agent, a GW, a phone and how the communications and protocols are handled"
"A: With the call control agent, CUCM. "
How do I know if I have the Call Control Agent?
Cisco Call agents are only CUCM or CUCME, so you most likely will have one.
Read the overview of CUCME or CUCM to understand what a call agent does and provides.
Using Call Flows to Resolve Call Processing Problems
http://www.cisco.com/iam/unified/ipt611/Using_Call_Flows_to_Resolve_Call_Processing_Problems.htm
Sample of Debug MGCP Packets
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080174804.shtml
The study material for CCVP is also a very good reference to understand all this.
java
java
Yes,
Very helpful, thanks.
Couple more questions,
When checking to see if the gateway is registered in Call Manager, on the Gateway end we can entr "sh ccm-manager"
But on the Call Manger end, we can go to gateway from the Management application and the only thing you see is
Status-Ready
Is this the only way to determine if the Gateway is registerd on the Call Manager end?
Sometimes I will see logs in the gateway showing the phone has unregistered normally and registered.
Jul 12 20:40:08.543: %IPPHONE-6-UNREGISTER_NORMAL: ephone-3:001FCAE77A1C IP:10.2.1.4 Socket:2 DeviceType:Phone has unregistered normally.
Jul 12 20:40:09.051: %IPPHONE-6-UNREGISTER_NORMAL: ephone-1:001FCAE779E6 IP:10.2.1.5 Socket:4 DeviceType:Phone has unregistered normally.
Jul 12 20:40:09.307: %IPPHONE-6-UNREGISTER_NORMAL: ephone-4:001FCAE7797D IP:10.2.1.1 Socket:1 DeviceType:Phone has unregistered normally.
Jul 12 20:40:20.151: %IPPHONE-6-UNREGISTER_NORMAL: ephone-2:001FCAE7798A IP:10.2.1.3 Socket:3 DeviceType:Phone has unregistered normally.
Jul 13 13:40:49.836: %IPPHONE-6-REGISTER_NEW: ephone-3:SEP001FCAE77A1C IP:10.249.120.4 Socket:3 DeviceType:Phone has registered.
Are these registrations in Call Manager?
That might be CME or SRST you're running.
java
java
Yes SRST is configured to fail back to the PRI when the link to the main site is lost.
Is this registration on the gateways?
If so, is it seperate or in addition to the registration of the phones in Call Manager?
Also, this question:
"Status-Ready"
on that particular gateway page.
SRST is a mechanism for phones to fallback to a router that provides basic call functionality because the communication phone-CUCM is down.
Search srst in CCO for greater details if you want further info
sh ccm-manager only proves the keepalives are being sent between the MGCP GW and CUCM, a sh mgcp endpoints is better command for registration.
On CUCM simply go to the endpoint page and see if it shows as registered or not.
java
java
Yes, I knew that SRST was the failback mechanism, but I had specific questions about it.
For example, if Call Manager is remotely controlling the gateway, are the dial peers needed in the router config without SRST?
Or are the dial peers in the config to be used by the SRST function only when the gateway looses connectivity with Call Manager?
Yes, if the GW is MGCP and you have SRST the dial-peers that are not marked for MGCP are for SRST
MGCP GW without SRST only contains MGCP related dial-peers
java
java
Excellent,
Thanks.
So in the below examples,
Dial peers 1, 9010 and 61 are for Call Manager to control and the rest are for SRST failback,
is that correct?
dial-peer voice 1 pots
description MGCP Inbound Calls from PSTN
service mgcpapp
incoming called-number .
direct-inward-dial
port 0/1/0:23
dial-peer voice 2 pots
description Emergency 911 dialing
translation-profile outgoing CALLERID
destination-pattern 9911
direct-inward-dial
port 0/1/0:23
forward-digits 3
dial-peer voice 9010 pots
description MGCP Dial-peer for 0/1/0
service mgcpapp
port 0/1/0:23
dial-peer voice 61 pots
description FAX line
service mgcpapp
destination-pattern 1234567
port 0/2/0
dial-peer voice 3 pots
description 7 digit Local Dialing
destination-pattern 9[2-9]......$
direct-inward-dial
port 0/1/0:23
Yes, that's correct.
java
java
