07-22-2009 05:56 AM - edited 03-11-2019 08:57 AM
07-26-2009 06:38 PM
The command that you are looking for is:
interface hardware_id hardware_speed [shutdown]
For instance, this command will enable port ethernet0:
interface ethernet0 auto
This command will disable it:
interface ethernet0 auto shutdown
Here is the command reference for Pix 6.3 for the 'interface' command:
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/gl.html#wp1075586
07-22-2009 06:06 AM
The port is closed - to open is issues the "no shut" command in the interface config. To place it in admin down again issues the "shut" command in the interface.
HTH>
07-22-2009 06:25 AM
Thanks Andrew that was very helpful.
Would you happen to know the correct usage to issue a no shut command for ethernet0 on a PIX 515e running 6.3. I am in conf mode.
Thanks again.
07-22-2009 06:32 AM
np - glad to help
07-26-2009 06:38 PM
