Wireless and VLAN's
Jul 22nd, 2009
Still relatively new to the wireless world. I've had a proposal handed to me and not exactly sure how it works. I have a 2940 switch, 2106 controller, 1522 RAP, 1522 MAP. I have VLAN A and VLAN B on the switch. VLAN A goes to the company network and VLAN B is privately addressed and has the 2106/1522's connected. I have two wireless laptops, one configured for VLAN A, one for VLAN B (private address). How/Where is the communication handled for these two laptops when connecting to the 1522 AP's through the "B" VLAN?
mat.edwards Thu, 07/23/2009 - 02:50
Once a client connects to the appropriate SSID, this SSID is mapped to a dynamic interface on the WLC which specifies the VLAN (B) this interface will also need an IP address within VLAN B's subnet.
The WLC will then trunk VLAN B to the switch then from there wherever you need it to go...
Ideally you will use the management interface of the WLC seperately to that of VLAN B in which case you will also need to trunk that VLAN to the switch.
Hope this helps. If you need further detail ask.
Mat
George Stefanick Fri, 07/31/2009 - 07:00
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
*delete*
