Disable Default WebVPN Page
Jul 22nd, 2009
I am setting up a few different WebVPN profiles I am wondering if there is any way to disable the default page. I am going to give all users specific URLs (https://mywebvpn.mydomain.com/myprofile) but I would like to completely disable the page if they try browsing to https://mywebvpn.mydomain.com. I havent been able to find a setting yet that will disable the main page but still allow access to all group-urls. I have tried adding in the https://mywebvpn.mydomain.com to the default WebVPN group and checking disable, but it still loads the webpage when going to that URL.
hadbou Tue, 07/28/2009 - 05:50
To specify a URL for the web page that displays when this WebVPN user logs in, enter the homepage command in username webvpn configuration mode. To remove a configured home page, including a null value created by issuing the homepage none command, enter the no form of this command. The no option allows inheritance of a value from the group policy. To prevent inheriting a home page, enter the homepage none command.
The none keyword indicates that there is no WebVPN home page. It sets a null value, thereby disallowing a home page and prevents inheriting a home page.
The url-string variable following the keyword value provides a URL for the home page. The string must begin with either http:// or https://.
There is no default home page.
