Cannot login CCA 2.0 asking for level 15 access
I can access the UC500 we have in every way except through the CCA.  I am looking to upgrade to the latest code and everything I see states that it should be done through CCA.  I create the connection to the UC500 but it asks for a level15 username and password.  I cannot determine what should go there?
Any help would be great
Todd
Steven DiStefano Wed, 07/22/2009 - 07:53
  • Blue, 1500 points or more
I assume you are talking about the little challenge windows that POP up when CCA is first discovering the community?
If so, hust enter the same credentials you use for the UC500 when you SSH or TELNET or COnsole to it.
Steven Smith Wed, 07/22/2009 - 07:56
  • Gold, 750 points or more
You should have a user with priviledge level 15 on the system.
If you do a show run | inc username
You should see something like
username cisco privilege 15 secret $asl;kdjfalsjdfo1230124n134
Have a user with privilege 15 and use that for the credentials.
Steven Smith Wed, 07/22/2009 - 10:04
It should also present an IP when it does this.  If you have more than one device, it could be asking for access to another device.  What IP is asking?
Steven Smith Wed, 07/22/2009 - 10:13
Can you post the config of the UC500 here?  Be sure to remove passwords.
Can you try this from another computer as well to see if you get the same problem?  Can you also get the CCA logs and post them here?
