what is the purpose of this command "spanning-tree vlan 10,92 cost 10"
Jul 22nd, 2009
interface GigabitEthernet0/1
switchport trunk native vlan 92
switchport trunk allowed vlan 10,92
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
queue-set 2
mls qos trust cos
auto qos voip trust
Giuseppe Larosa Wed, 07/22/2009 - 11:13
  • Hall of Fame,
    Founding Member
it modifies (increases) the STP cost for vlans 10 and 92 from default value to 10
These two vlans are also the only two vlans permitted on this L2 trunk.
Hope to help
Giuseppe
CCDECCDE9 Wed, 07/22/2009 - 11:24
if you see the config,both the interfaces have same config except this line...what does this mean ?
Giuseppe Larosa Wed, 07/22/2009 - 11:36
  • Hall of Fame,
    Founding Member
that int gi0/1 the one without the STP cost command would be chosen as root bridge for vlans 10,92 if both links receive equal cost STP BPDU because cost to root bridge is calculated summing to cost in received BPDU the cost of the port where it is received.
So it is likely that G0/4 should act as backup path to root bridge.
if local switch is root bridge for vlans 10,92 there is no practical difference.
Hope to help
Giuseppe
