Warning message
Services on IP Phone 7942
Jul 22nd, 2009
I've wanted to set up speed dialing but when I hit services, I am prompted to go to the following address... https://10.4.112.10:8443/ccmuser/showHome.do
When I get there (Cisco Unified CM Administration) a user name and password is required but it is different than the one I use to get on this site.
So does anyone know how to generate a user ID and password for the site above?
Barry
Jaime Valencia Wed, 07/22/2009 - 09:20
  • Cisco Employee,
  • Hall of Fame,
    2011
If you don't know your credentials get in touch with your system admin so he can provide it to you.
BTW: that's not CCMAdmin, that's CCMUser
java
if this helps, please rate
