07-22-2009 08:50 AM
Hello everybody,
I've run into a very odd problem. I am unable to copy anything (configs, or binaries) from my router (a 2801) to a TFTP server. I get timed out every time.
I've verified network connectivity, there are no firewalls blocking it, and the service is running properly. As a side note, I am able to save my config from a 3550 switch sitting on the same network to the same TFTP server...with no problem. This only occurs with my 2801 router.
Any guidance would be helpful!
Sean
07-22-2009 09:14 AM
Check your access-lists on the 2801
Try to use ftp as a workaround.
There is a communication issue somewhere.
07-22-2009 02:50 PM
Hi Sean,
Did you enable TFTP in your router?
conf t
tftp flash:
end
07-22-2009 06:23 PM
You dont need this if you copy from the router to the server.
You would need it if the router is the tftp server
07-22-2009 06:23 PM
