SPA9000 dropping incoming calls within a few seconds, immediate callback holds fast.
Jul 22nd, 2009
We have a SPA9000, current firmware, SPA962 and SPA942 setup...
Essentially what seems to be happening is that incoming calls are dropping within a few seconds very commonly and usually when the caller tries again the call will stick.  I've also noted from my cellphone that calls drop very frequently on transfer to voicemail to our SPA400.
Outgoing calls are just peachy.
Now, i'll note we've used the WAN interface on the SPA9000, as our internet provider is actually supplying us with the SIP trunks over fiber to our location.  We have a static external IP assigned to the WAN interface on the router and a static IP assigned for our internal LAN.
We consistently have 10-15mbps up AND downstream and they have QOS configured through their equipment.
I'm hoping to eliminate the SPA9000 as the problem and then take it to my ISP/voip-provider for troubleshooting the SIP trunks.
I can post debug info and will collect some today.
Any ideas would be helpful!
UPDATE:
Here's the debug from a two-call sequence.  First call dropped within seconds of pickup, second was solid to completion.
[2]<<199.234.69.132:5060(813)
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 199.234.69.132:5060;rport;branch=z9hG4bK-8d0fe1e88a0297cce83df143e0322fb8-199.234.69.132-1
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info
Max-Forwards: 70
Call-ID: [email protected]: Anonymous <sip:[email protected];transport=udp>;tag=199.234.69.132+1+41edf0+d8bf536d
From
To: <sip:[email protected]>
CSeq: 575241355 INVITE
Expires: 180
Organization: Full Service Network
Supported: 100rel
Content-Length: 170
Content-Type: application/sdp
Contact: Anonymous <sip:[email protected];transport=udp>
v=0
o=- 2742917414 2742917414 IN IP4 199.234.69.142
s=-
c=IN IP4 199.234.69.142
t=0 0
m=audio 33248 RTP/AVP 18 0 101
a=rtpmap:101 telephone-event/8000
a=ptime:20
[2]->199.234.69.132:5060(401)
SIP/2.0 100 Trying
From: Anonymous <sip:[email protected];transport=udp>;tag=199.234.69.132+1+41edf0+d8bf536d
Call-ID: [email protected]: 575241355 INVITE
CSeq
Via: SIP/2.0/UDP 199.234.69.132:5060;branch=z9hG4bK-8d0fe1e88a0297cce83df143e0322fb8-199.234.69.132-1
Server: 192.168.2.200
Allow-Events: talk, hold, conference
Content-Length: 0
[AA]: aa 1 auto answer delay = 0
[7:0]AAA ALLOC CALL (port=16442)
[7:0]AAA:RTP Rx Up
pri--180-->BCC--180-->pub
[2]->199.234.69.132:5060(554)
SIP/2.0 180 Ringing
To: <sip:[email protected]>;tag=28890981bee902fci2
CSeq
Contact: "" <sip:[email protected]:5060>
Remote-Party-ID: "" <sip:[email protected]>;screen=yes;party=called
Content-Length: 0
CC:Connected
[7:0]AAA:Create AA Object
[7:0]AAA:RTP Tx Up (pt=0->c0a802dc:16438)
[2]->199.234.69.132:5060(942)
SIP/2.0 200 OK
To: <sip:[email protected]>;tag=28890981bee902fci2;ref=aa
CSeq
Content-Length: 259
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
v=0
o=- 9024522 9024522 IN IP4 192.168.2.220
s=-
c=IN IP4 208.248.109.151
t=0 0
m=audio 16438 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 NSE/8000
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
[2]<<199.234.69.132:5060(588)
ACK sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 199.234.69.132:5060;branch=z9hG4bK-e9fb72897ed7c3df2c11bc3ce8fb4e93-199.234.69.132-1
Max-Forwards: 70
From
CSeq: 575241355 ACK
Content-Length: 0
[0:0]RTP Rx 1st PKT @16442(2)
[2]->199.234.69.132:5060(436)
NOTIFY sip:fsn1.fsnnet.net SIP/2.0
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-43d614c7
From: "" <sip:[email protected]>;tag=e57bfc44576dc561o2
To: <sip:fsn1.fsnnet.net>
Call-ID: [email protected]: 6012 NOTIFY
CSeq
Max-Forwards: 70
Event: keep-alive
User-Agent: Linksys/SPA9000-6.1.5
Content-Length: 0
[2]<<199.234.69.132:5060(405)
SIP/2.0 404 To: user name not found
To: <sip:fsn1.fsnnet.net>;tag=199.234.69.132+1+0+988e77c0
Via: SIP/2.0/UDP 208.248.109.151:5060;received=208.248.109.151;branch=z9hG4bK-43d614c7
Server: DC-SIP/2.0
Content-Length: 0
Retry-After: 4
CSeq
AVT Rx Start Tone: 3
AVT Rx End Tone
[0:0]LAT-- 6(2)
[AA]: xfer to target=2001
CC:BlndXferTgt:2001
Calling:[email protected]:6060
[7:0]AAA Rel Call
[7:0]AAA:Destory SAA OBJ
pri--REFER-->BCC:[email protected]:6060
pri--18x-->BCC(conn)
[4]RegOK. NextReg in 28 (1)
+++ full fxo report
+++ full fxo report
+++[4]fxo port mask = 0
[2]<<208.248.109.151:5062(353)
SIP/2.0 200 OK
To: <sip:[email protected]:5062>;tag=eeb9301033574405i4
From: "SPA400" <sip:[email protected]>;tag=as327b23c6
Call-ID: [email protected]: 43929 NOTIFY
CSeq
Via: SIP/2.0/UDP 192.168.2.221:5060;branch=z9hG4bK0a63406d
Content-Length: 0
[4]SubOK. NextSub in 29 (1)
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-86017f0c
Call-ID: [email protected]: 6013 NOTIFY
CSeq
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
[2]<<199.234.69.132:5060(380)
To: <sip:fsn1.fsnnet.net>;tag=199.234.69.132+1+0+4bc2ab8a
Server: DC-SIP/2.0
Content-Length: 0
Retry-After: 4
CSeq
[2]<<199.234.69.132:5060(833)
Via: SIP/2.0/UDP 199.234.69.132:5060;rport;branch=z9hG4bK-35dedebe79dd985049d3d14df5a63dbe-199.234.69.132-1
Max-Forwards: 70
From
CSeq: 575241356 INVITE
Expires: 180
Supported: 100rel
Content-Length: 167
v=0
s=-
t=0 0
m=audio 33248 RTP/AVP 0 101
a=ptime:20
SESS:NoDlg to handle c=17
[2]->199.234.69.132:5060(424)
SIP/2.0 100 Trying
Call-ID: [email protected]: 575241356 INVITE
CSeq
Via: SIP/2.0/UDP 199.234.69.132:5060;branch=z9hG4bK-35dedebe79dd985049d3d14df5a63dbe-199.234.69.132-1
Content-Length: 0
ReferTarget answers BCC INVITE
pri(ReferTarget)--200-->BCC--reINVITE-->pub
[2]->199.234.69.132:5060(843)
INVITE sip:[email protected];transport=udp SIP/2.0
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-571387c7
From: <sip:[email protected]>;tag=28890981bee902fci2;ref=1000
To: Anonymous <sip:[email protected];transport=udp>;tag=199.234.69.132+1+41edf0+d8bf536d
Call-ID: [email protected]: 101 INVITE
CSeq
Max-Forwards: 70
Expires: 30
Content-Length: 211
v=0
o=- 9023863 9023863 IN IP4 192.168.2.38
s=-
t=0 0
m=audio 16438 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[2]<<199.234.69.132:5060(506)
SIP/2.0 401 Unauthorized
WWW-Authenticate: Digest realm="fsn1.fsnnet.net",nonce="54ba79e8971c",stale=false,algorithm=MD5,qop="auth"
CSeq
Server: DC-SIP/2.0
Supported: 100rel
Content-Length: 0
[2]->199.234.69.132:5060(502)
ACK sip:[email protected];transport=udp SIP/2.0
Call-ID: [email protected]: 101 ACK
CSeq
Max-Forwards: 70
Content-Length: 0
[2]->199.234.69.132:5060(1066)
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-2646a0eb
Call-ID: [email protected]: 102 INVITE
CSeq
Max-Forwards: 70
Authorization: Digest username="7242952447",realm="fsn1.fsnnet.net",nonce="54ba79e8971c",uri="sip:[email protected]",algorithm=MD5,response="7bc532a60d81a0966a7a8171cea84422",qop=auth,nc=00000002,cnonce="c79c3504"
Expires: 30
Content-Length: 211
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[2]<<199.234.69.132:5060(426)
SIP/2.0 491 Request Pending
CSeq
Via: SIP/2.0/UDP 208.248.109.151:5060;received=208.248.109.151;branch=z9hG4bK-2646a0eb
Server: DC-SIP/2.0
Supported: 100rel
Content-Length: 0
[2]->199.234.69.132:5060(725)
Call-ID: [email protected]: 102 ACK
CSeq
Max-Forwards: 70
Content-Length: 0
[2]->199.234.69.132:5060(1097)
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-bc05aa35
Call-ID: [email protected]: 103 INVITE
CSeq
Max-Forwards: 70
Authorization: Digest username="7242952447",realm="fsn1.fsnnet.net",nonce="54ba79e8971c",uri="sip:[email protected]",algorithm=MD5,response="e419e8ff5e5cf2703e88e2ee8e758dd6",qop=auth,nc=00000003,cnonce="c79c3504"
Expires: 30
Content-Length: 242
v=0
o=- 9027648 9027648 IN IP4 208.248.109.151
s=-
t=0 0
m=audio 16440 RTP/AVP 18 0 101
a=rtpmap:18 G729a/8000
a=fmtp:101 0-15
a=ptime:160
a=sendrecv
[2]<<199.234.69.132:5060(401)
CSeq
Server: DC-SIP/2.0
Supported: 100rel
Content-Length: 0
Call-ID: [email protected]: 103 ACK
CSeq
Max-Forwards: 70
Content-Length: 0
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-56a3cc98
Call-ID: [email protected]: 104 INVITE
CSeq
Max-Forwards: 70
Authorization: Digest username="7242952447",realm="fsn1.fsnnet.net",nonce="54ba79e8971c",uri="sip:[email protected]",algorithm=MD5,response="dfb9efa805bc4ed6d73eee2396853cb9",qop=auth,nc=00000004,cnonce="c79c3504"
Expires: 30
Content-Length: 242
v=0
o=- 9027804 9027804 IN IP4 208.248.109.151
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:160
a=sendrecv
Call-ID: 45564189@199.234.69.132: 104 INVITE
CSeq
From: <sip:7242952447@fsn1.fsnnet.net>;tag=28890981bee902fci2
To: Anonymous <sip:anonymous@fsn1.fsnnet.net;transport=udp>;tag=199.234.69.132+1+41edf0+d8bf536d
Server: DC-SIP/2.0
Supported: 100rel
Content-Length: 0
ACK sip:anonymous@fsn1.fsnnet.net;transport=udp SIP/2.0
From: <sip:7242952447@fsn1.fsnnet.net>;tag=28890981bee902fci2;ref=1000
Call-ID: 45564189@199.234.69.132: 104 ACK
CSeq
Max-Forwards: 70
Authorization: Digest username="7242952447",realm="fsn1.fsnnet.net",nonce="54ba79e8971c",uri="sip:anonymous@fsn1.fsnnet.net",algorithm=MD5,response="dfb9efa805bc4ed6d73eee2396853cb9",qop=auth,nc=00000004,cnonce="c79c3504"
Contact: "" <sip:7242952447@208.248.109.151:5060>
Content-Length: 0
INVITE sip:anonymous@fsn1.fsnnet.net;transport=udp SIP/2.0
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-ac26c8cb
Remote-Party-ID: "" <sip:7242952447@fsn1.fsnnet.net>;screen=yes;party=called
Call-ID: 45564189@199.234.69.132: 105 INVITE
CSeq
Max-Forwards: 70
Authorization: Digest username="7242952447",realm="fsn1.fsnnet.net",nonce="54ba79e8971c",uri="sip:anonymous@fsn1.fsnnet.net",algorithm=MD5,response="e6e14a38a89adc770d254311cc90be7d",qop=auth,nc=00000005,cnonce="c79c3504"
Expires: 30
Content-Length: 242
v=0
o=- 9028000 9028000 IN IP4 208.248.109.151
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:160
a=sendrecv
CSeq
Server: DC-SIP/2.0
Supported: 100rel
Content-Length: 0
Call-ID: 45564189@199.234.69.132: 105 ACK
CSeq
Max-Forwards: 70
Content-Length: 0
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-7cb24cb1
Call-ID: 45564189@199.234.69.132: 106 INVITE
CSeq
Max-Forwards: 70
Authorization: Digest username="7242952447",realm="fsn1.fsnnet.net",nonce="54ba79e8971c",uri="sip:anonymous@fsn1.fsnnet.net",algorithm=MD5,response="2a20a96e7f7d1eb9c76b5b1473391a49",qop=auth,nc=00000006,cnonce="c79c3504"
Expires: 30
Content-Length: 242
v=0
o=- 9028047 9028047 IN IP4 208.248.109.151
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:160
a=sendrecv
CSeq
Server: DC-SIP/2.0
Supported: 100rel
Content-Length: 0
Call-ID: 45564189@199.234.69.132: 106 ACK
CSeq
Max-Forwards: 70
Content-Length: 0
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-fe2aa549
From: "" <sip:7242952447@fsn1.fsnnet.net>;tag=e57bfc44576dc561o2
Call-ID: 39bb4758-726d55d@208.248.109.151: 6014 NOTIFY
CSeq
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
To: <sip:fsn1.fsnnet.net>;tag=199.234.69.132+1+0+7a9a38ba
Server: DC-SIP/2.0
Content-Length: 0
Retry-After: 6
CSeq
[2]<<199.234.69.132:5060(547)
BYE sip:7242952447@208.248.109.151:5060 SIP/2.0
Via: SIP/2.0/UDP 199.234.69.132:5060;rport;branch=z9hG4bK-2c2bc6d12f28d4b870bdca045ba50bbc-199.234.69.132-1
Max-Forwards: 70
Call-ID: 45564189@199.234.69.132: Anonymous <sip:anonymous@fsn1.fsnnet.net;transport=udp>;tag=199.234.69.132+1+41edf0+d8bf536d
From
To: <sip:7242952447@fsn1.fsnnet.net>;tag=28890981bee902fci2
CSeq: 575241357 BYE
Supported: 100rel
Content-Length: 0
[2]->199.234.69.132:5060(417)
SIP/2.0 200 OK
From: Anonymous <sip:anonymous@fsn1.fsnnet.net;transport=udp>;tag=199.234.69.132+1+41edf0+d8bf536d
Call-ID: 45564189@199.234.69.132: 575241357 BYE
CSeq
Via: SIP/2.0/UDP 199.234.69.132:5060;branch=z9hG4bK-2c2bc6d12f28d4b870bdca045ba50bbc-199.234.69.132-1
Content-Length: 0
BCC:Ended
INVITE sip:7242952447@208.248.109.151:5060 SIP/2.0
Max-Forwards: 70
From
Expires: 180
Contact: Anonymous <sip:anonymous@fsn1.fsnnet.net;transport=udp>
Supported: 100rel
Content-Length: 167
v=0
s=-
t=0 0
a=ptime:20
SIP/2.0 100 Trying
Call-ID: 45564189@199.234.69.132: 575241356 INVITE
CSeq
Content-Length: 0
+++ full fxo report
+++ full fxo report
SIP/2.0 200 OK
To: <sip:9000@208.248.109.151:5062>;tag=eeb9301033574405i4
From: "SPA400" <sip:SPA400@192.168.2.221>;tag=as327b23c6
Call-ID: 0dc379c62486d023664fa591333afdad@192.168.2.221: 43930 NOTIFY
CSeq
Via: SIP/2.0/UDP 192.168.2.221:5060;branch=z9hG4bK295c2521
Content-Length: 0
DLG Terminated 3a22a0
Sess Terminated 3b6574
Via: SIP/2.0/UDP 208.248.109.151:5060;branch=z9hG4bK-c119912b
Call-ID: 39bb4758-726d55d@208.248.109.151: 6015 NOTIFY
CSeq
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
To: <sip:fsn1.fsnnet.net>;tag=199.234.69.132+1+0+3ba290da
Via: SIP/2.0/UDP 208.248.109.151:5060;received=208.248.109.151;branch=z9hG4bK-c119912b
Server: DC-SIP/2.0
Content-Length: 0
Retry-After: 1
CSeq
Message was edited by: ssijschneider
Patrick Born Wed, 07/22/2009 - 13:50
  • Cisco Employee,
Hi ssijschneider,
The INTERNET port on the SPA9000 is the recommended way to connect the device, so this should not present any problems...
I'm not clear what you mean by: "We have a static external IP assigned to the WAN interface on the router and a static IP assigned for our internal LAN."
Are you saying that you have configured and are using the SPA9000's ETHERNET port?
If so, this could present all types of problems, depending on traffic through the SPA9000's router.
Our best practices recommend connecting only the SPA9000's INTERNET port, as described in the Installation Guides [Wizard and web-ui]: https://www.myciscocommunity.com/docs/DOC-1751
Is this a new installation? If so, consider using the Setup Wizard to properly configure the system: https://www.myciscocommunity.com/docs/DOC-8126
I looked through the log that you posted, but don't see anything obvious. Can you capture a Wireshark trace please?
Patrick
ssijschneider Wed, 09/09/2009 - 08:37
Patrick,
Since your last post, i've reconfigured the setup to run through the internet port on the SPA9000 as recommended.  We're up and running with the same issue, and i've pretty conclusively eliminated my LAN as the issue as all LVS devices are 100mb full duplex to an SRW2024 and it's showing 0 collisions, good traffic, etc.
Here's a wireshark trace of the same caller dropping repeatedly:
Thanks for your help!
Patrick Born Fri, 09/11/2009 - 16:04
  • Cisco Employee,
Hi ssijschneider,
Looking through the trace, I don't see anything obvious.
I'm going to escalate this to support. [this is not official support, so feel free to contact official support channels if your need is urgent]
I need the following please:
1. Current config from SPA9000: https://supportforums.cisco.com/docs/DOC-9861
2. Current config from SPA400: https://supportforums.cisco.com/docs/DOC-9865
3. Current config from a phone displaying this problem: https://supportforums.cisco.com/docs/DOC-9933
4. syslog log with debug from each device:
https://supportforums.cisco.com/docs/DOC-9934
https://supportforums.cisco.com/docs/DOC-9863
https://supportforums.cisco.com/docs/DOC-9864
5. Wireshark trace of events.
Basically I need you to:
1. get everything ready, start the Wireshark trace, start the syslog server, and then make several calls.
2. write a description of what happens and when it happens so it's easy to find in the log files.
Patrick
khumprakob Mon, 10/04/2010 - 08:34
Hello - I'm having the same problem. Probably started up about 3 months ago, and I don't know why.
Seems like the first call for the day gets cut off after a few seconds, but then when they call back, it stays on the line fine.
Does anyone have any results in fixing this?
Thanks!
