Code upgrade to 4.2.205 FIASCO>>>>>
Going from 4.2.112 to 4.2.205 along with boot image. The AP's have Static IP.
1. Upgraded backup controller.
2. Using WCS template changed the primary and secondary controller for group of AP's. This will move them.
3. Repeated above step till all the 100 AP's moved to backup controller and got the new code.
4. Upgraded the code on the primary.
Using WCS template moved the AP's back to primary.
out of 100 only 5 AP's moved. Remaining AP's lost the IP address and the AP group VLAN.
Had to create the DHCP scopes for each location to bring them on network and add AP group VLAN.
Got to move another 120 AP's. TAC does not what might have caused this.
ericgarnel Thu, 07/23/2009 - 05:25
With the 440x & wisms, only 10 APs will upgrade at a time.
Have you tried either of the following:
rebooted both controllers at the same time
made the upgraded controller the "master"
and AP fallback enabled on the controllers?
In the past, we were reluctant to use WCS to drive things opting to drive from the WLC , but it is much better in 6.x
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
