ASA has no flash / disk0 PLEASE HELP
Jul 22nd, 2009
We had a backup ASA 5510 die. When consoled in I saw that it could not find an image. I did a tftpdnld and got it up. Now the issue is that it does not recognize its flash or disk 0. When I do a fsck it says unrecognized format, and if I try to do a format it says no such file. What do I need to do since this is not under smartnet??
hobbe Tue, 07/28/2009 - 23:58
are the ASA5510 the same when it comes to the licencing ?
Then just take the flash from the broken one and replace the non functioning one with.
I dont know if this voids warrantys and so on, but if I had your problem I would exchange the flash cards between the firewalls.
then you have the right config, the right version and so on.
