07-22-2009 12:13 PM - last edited on 03-25-2019 10:40 PM by ciscomoderator
I have some programs that can utilize TAPI. Is there a free way to get TAPI setup on the PC to use with the UC520 other than 'CallConnector Popup'?
07-22-2009 12:19 PM
You can use the generic TSP offered in windows to create a connection that can be used by your applications. Example here:
"Easy way to control an IP Phone remotely"
https://supportforums.cisco.com/docs/DOC-9644
Marcos
07-22-2009 03:15 PM
Hi Mantis,
I also use the following:
Cisco-CUCME-TSP-2.1.2
Has worked for me from day one :)
Give it a run and see if it works for you, if not then use the generic MS one.
Cheers,
David.
