Meet Me Number calling
Jul 22nd, 2009
I have CCM 4.X. Users at the remote site cannot call the meetme numbers. They get busy signal.The remote site is configured with different device pool and location settings.
Jaime Valencia Wed, 07/22/2009 - 14:43
  • Cisco Employee,
  • Hall of Fame,
    2011
If you're using SW CFB make sure you're using G711, if you're using G729 or any other codec you need either a HW CFB or XCODER.
Just by what you explained it seems you have codec issues.
java
if this helps, please rate
