CUCM6.1.3a - dbreplication failure
Jul 22nd, 2009
I had a problem with the cluster after upgrading the to 6.1.3a.
I added a new sub to the cluster. It installed fine however under dbreplication in rtmt it showed a status of 0.
I opened a tac and the last action plan was to perform a utils dbreplication clusterreset.
I followed the procedure but the command is looping when defining the problem sub. See the attachment.
Also now in the rtmt some subs and the pub are showing a status of 3 and some subs a status of 0
Has anyone come across this before or have any suggestions.
Tommer Catlin Wed, 07/22/2009 - 13:46
Id reboot the whole cluster, then let it sit for about 6 hours. Then try again. Sometimes it takes quite awhile for replication to get settled. If not, reload the subscriber from scratch and start over. Takes only 2 hours at most. (then replication)
agtmcgarry Wed, 07/22/2009 - 14:04
The problem sub had been on the cluster for two weeks with a bad replication status. The tac engineer tried multiple commands with no joy.
I then removed the sub and reinstalled. Still the same problem.
I believe that it was a bug in 6.1.3a adding a new sub to the cluster but the workaround did not work.
This rebuilt sub still had the issue so the tac engineer advised the clusterreset.
This is where I am at now.
I am thinking that maybe if I delete this problem sub from the publisher database and shut it down. Then rerun the clusterreset and see if I can get the cluster back to a status of 2 then perform a reboot.
