07-22-2009 01:36 PM - edited 03-09-2019 10:27 PM
Running SDM ver. 2.5 with latest JAVA and connecting to a Cisco 831 running IOS 12.4x.
Used to work 100% in the past for me, but now there seems to be some odd problems showing up. The most prominent is when trying to run the "security audit" function, I click the box, the button grays-out, and the security audit wizard never starts.
Almost seems like there is a problem with the way JAVA is trying to open the wizard, but just can't do it for some reason. I've even un-installed SDM 2.5 and reinstalled it, and checked for the latest JAVA updates from java.com (I've got the latest) but still it does the same thing. Is it possible a recent JAVA update could have messed with the way SDM tries to use JAVA?
Any thoughts appreciated, and thanks.
07-22-2009 09:28 PM
The latest Java does NOT work with SDM.
Please use the java on the release notes:
Cisco SDM requires Sun Java Runtime Environment (JRE). The following versions are supported:
â¢JRE 1.5_09
â¢JRE1.4.2_08
â¢JRE 1.5.0_06
â¢JRE 1.5.0_07
â¢JRE 1.6.0_02
â¢JRE 1.6.0_03
07-25-2009 04:21 AM
Nice! Went into Settings --> Control Panel --> Java, selected the Java tab, clicked 'view...', and enabled only 1.6.0_03 and life is wonderful again. Thanks friend.
