CallManager 7.1.2a java.sql.SQLException on Route Pattern entry
Jul 22nd, 2009
  • Bronze, 100 points or more
I am unable to make the required Route Pattern changes due to the following error within CCM administration. "Error occurred during find. java.sql.SQLException: Ambiguous column (tkproduct).
Have you run into this issue yet?
ldardon Tue, 07/28/2009 - 14:37
Check the similar bug: CSCsq74372: find button for Calling Search Space in DNA does not work
kking2008 Wed, 07/29/2009 - 13:05
I had a simiar issue, this is what the TAC engineer did to resolve it for us.
Login in publisher as administrator
admin:run sql update device set internationalprefix = 'Default', internationalstripdigits = null, nationalprefix = 'Default', nationalstripdigits = null, subscriberprefix = 'Default', subscriberstripdigits = null where tkproduct = 95
Rows: 6
admin:run sql update device set internationalprefix = 'Default', internationalstripdigits = null, nationalprefix = 'Default', nationalstripdigits = null, subscriberprefix = 'Default', subscriberstripdigits = null where tkproduct = 95 and (internationalprefix <> 'Default' or nationalprefix <> 'Default' or subscriberprefix <> 'Default')
Rows: 0
restart the CM service
