ASA Static Route Tracking question
Jul 22nd, 2009
I'm about to implement static-route tracking with the below setup:
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address
interface Vlan3
nameif backup
security-level 0
ip address
route outside 1
Before I implement, I'd like to test to make sure Vlan3 has connectivity.
I try and do "ping" and enter "backup" as interface and I'm able to ping the "backup" gateway.
Then I try and ping "" with same method and get no replies.
I then do "ping" and get responses.
I assume this is because right now the ASA is going to push all traffic, regardless of source, through the "route 0..."
So my question is:
Is there any way to send/receive packets through the "backup" interface before implementing SRT (static-route-tracking)?
I just want to make sure the backup line is up and running, and I'm not currently in the office.
robertson.michael Thu, 07/23/2009 - 07:47
Hi Scott,
You could add a static route that is more specific than your active route 0 default route. I would try something like this:
route backup
With this route, your ping to should use the backup gateway connected to the backup interface.
Keep in mind you'll probably also need a valid translation for this interface as well. You may already have this but the config examples you posted didn't include it.
Hope that helps.
