LMS 3.x device backup not happening
Jul 22nd, 2009
I have LMS 3.x, though i have scheduled device backup on a daily basis, not all the devices are backed up in the folder called "shadow>switches and hubs>primary". Can some one provie me a quick fix or troubleshooting steps.
-Regards
PRS
Joe Clarke Thu, 07/23/2009 - 09:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you perform a Sync Archive job on one of the devices which does not have a shadow config, does the config get created? Does the job complete successfully? If not, you can check the dcmaservice.log for errors.
