LINEPROTO UP/DOWN in same Second
kmmehlkmmehl
020221: Jul 23 07:52:23: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/2, changed state to down
020222: Jul 23 07:52:23: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/2, changed state to up
020223: Jul 23 07:52:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/2, changed state to down
020224: Jul 23 07:52:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/2, changed state to up
Any IDeas?
I see this every few half hours
6 Replies 6
andrew.prince
Level 10
Level 10
check the device that connects to the port.
HTH>
Thanks. The other side is showing no LINEPROTODOWN at all!
Is it a fiber or a copper port? Is it possible to test the connection using a proper testing equipment? Also, if you connect the link into a different port, does that port behave in the same way?
I also recommend checking the interface counters on both sides of the link to see if there are any transmission errors that would suggest a problem with the medium.
Best regards,
Peter
Hi!
Thanks!
Its fiber.
Actually i see not CRC Errors. Only Symbol errors every now and then. I will try to connect them to a different port.
Actually i had the same problems with another port i moved from 2/0/6 to 2/0/8
whis was fine and AFTER that the problems startet with the other 2 ports 2/0/1 2/0/2
You my have a cross fibre - try swapping over the connections
This means swapping the fibres?
Is this some kind of Cross Talk?
