SRST Issue
Jul 23rd, 2009
I confiured SRST into my voice gateway, but when WAN link is down, IP phones doesn't register on SRST, it shows "Registering" continuously..
Plz find attached the SRTS config on the voice gateway & suggest....
In CCM SRST references are created....
tiago.moreira Thu, 07/23/2009 - 02:49
For what I can see, you need to enable fallback on the router.
Assuming you have configured in CCM, the SRST reference to use local gateway, here's an example of fallback configuration:
call-manager-fallback
secondary-dialtone 9
transfer-system full-consult
ip source-address 172.16.27.2 port 2000
max-ephones 15
max-dn 30
transfer-pattern .....
Let me know if it works...
acharyr123 Thu, 07/23/2009 - 03:54
I will add the 3 commands as per your config:
I did the folowing in the Voice gateway for Fallback..
max-ephones 52
max-dn 100
dialplan-pattern 1 9… extension-length 3
keepalive 20
